Lets see what r33_racers failure was caused by before we go jumping the gun.
True, it may not even be that.
But while on the subject, does anyone run any 'engine kill' devices that detect low oil pressure and cut ignition to help save the motor? Is there a separate device like this available? A light on the dash doesn't give much time to react when at high revs, but perhaps a sensor to trigger ignition kill would be the go...
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :laugh:
Kill ignition and it may lock the rears mid corner or something silly.
I've thought about a warning buzzer, not sure if killing ignition is the way to go, probably just better off with a buzzer so you can drop it in neutral asap. Providing you don't forget about the buzzer, it goes off and you think wtf is that, by the time you remember its too late anyway. :P
mate runs an engine kill switch like the one suggested on his sprint car, with over $60K in the engine, as soon as the oil pressure drops, it cuts everything.
with our cars it might ne a little harder than the carbied V8.. as you have to bypass any chance of a turbo timer working etc, then power steering and where you are.
but i am DEFINATELY going to run a switch to a specific light (autometer pen light for example) that will be direct line of sight. might not save the rebuild, but you wont go seizing anything.
yeh i think motecs and autronics have that feature built in, if something goes over a preset warning value it shuts off the engine completely to save it from harm. I know alot of sprint car racers and even circuit racers have a kill switch hooked inline to the oil pressure switch which craved is talking about so it kills the engine if pressure drops to nothing. I think we wish we had that now haha >_<
Well my motor is nearly ready to go back in my car so hopefully thursday/friday the rb30det will be out and getting stripped down....we found a strip of steel/tin in the oil, looks like its from a bearing... :P
Oh also cubes...things we would do differently... Well our tuner wants us to run a flat 8:1CR. Id like to run 9:1, but they like it lower to help keep the knock down, so can run more timing and boost. Will definetely do all the oil control mods that SK listed properly, instead of letting my old man half arse them cause he thinks he knows better haha, umm defintealy run conrods with oil squirters and thats about it so far that i can think of. Will probably come up with more as we put it back together.
Edited by r33_racer
quickie -
what engine sealant did you guys use on the replacement whelsh plugs .. i have a black sensor safe engine sealer i used on my bike, would this suffice?
or something like a tri bond sealer be best?
Edited by Craved
Just fitted front facing plenum, what a nitemare, even check out my new clutch master cylinder to compensate for plenum size :no:, now bonnet does close :), all thats left to do is the final wiring for injectors, z32 and apexi ebc then ill crank 20psi and see what she can push at all 4 wheels!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
