Ok , so from reading this im guess a rb30(n/a) bottom end will not just bolt straight in....
i have a rb25det (automatic) in a R33 gtst i dont wanna change driveline .
Will my box fit? will the engine mounts match ? its a great thread but im just looking to bolt on the rb30 bottom end without changing pistons and grinding galleries? is this possible???
thanks in advance
Edited by Veilside-SaU
Im pretty sure all spigot bearings are the same. rb30, 25, 20 and 26 identical. Ask for an rb30 spigot bearing...chances of finding that are probably better as its from an australian car...some automotive stores dont know any better. Ask for a 26 and the list will only say rb30....and the pimple faced kid behind the counter will say 'sorry sir the computer only lists one for an rb30 out of a vl commondore, cant help you...'
Idiots...annoying sometimes.
RE: Belt sizes.
Just been looking on dayco.com.au, heaps of belt options.
94843: 153 teeth, STP8M pitch, 25mm wide (not that it needs to get any longer)
94407: 152 teeth, STP8M pitch, 25mm wide
94604: 151 teeth, STP8M pitch, 25mm wide
94777: 150 teeth, STP8M pitch, 23mm wide (this belt is equiv to gates t306,150 teeth)
94830: 149 teeth, STP8M pitch, 25mm wide (pretty much spot on for low low setup)
94109: 148 teeth, STP8M pitch, 25mm wide
94652: 147 teeth, STP8M pitch, 25mm wide (getting a bit short....)
Hope this helps a few people, Im gonna work out the best one for the low low tensioner setup for mine, will post up results.
Edited by Godzilla33
hi guys i have these pistons
AP340754 Arias - Arias Forged Pistons Rb30 Non-turbo 86.5mm Bore Supplied With Rings
how good are they for this conversion???
what comp ration would it give with 1.5mm head gasket and rb25 vvt head?? and the block has been faced if that makes a big diff (not sure how much tho)
the non-turbo pistons are better for this conversion yee? or is that just the standard non-turbo pistons which are better??
whats teh differance in strength between the turbo and non turbo pistons?
Hey Scooby,
yeah, pitch is the same as std RB30 belt, Im 99% gonna use the 149 tooth option with the low low 2 tensioner setup. Gives that bit more clearance between tensioners. My local Repco doesnt stock dayco, gonna try get one tomorrow elsewhere.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
