The tuners still have our car...been there all week. Car wont make more power then about 290rwkws and it keeps overboosting once it reaches its target boost. They have been playing with timing, and wastegate springs....they think the problem is a faulty gate, which is sticking or something...so another is coming from turbosmart which will hopefully clear it up.
Initial thought after playing with wg springs was that the timing was out a few degrees, as in piston was not tdc when we set it up...But now the blame has been shifted back to the wastegate. Hopefully it gets sorted cause races are next weekend. Car still needs a wheel alignment.
R33 Racer- What size wastegate you using?
48mm turbosmart progate....the exact one we used previously on the old motor before it died.
The only different things on this new motor is the dry sump system, gt3540 0.82a/r, 4" exhaust system, oh and not that it matters but argo rods(previously ran rev)....so it went from making 370rwkws to 290rwkws.
with 8.5 to 1 what does a compression test come out at? mine has 120 in each cyl and i was wondering what it was.
comp ratio is 8.5:1
had several bolt on probs previously to this run, which I ve recently sorted, bent plenum, fuel pump issues.
But fixed all those, new 044 pump etc. No leaks, A/F ratios all good now.
I agree cubes, I told Matt that this Friday to boost it until it pings :-) , as the engine will handle near enough what ever we put into it.
Ill be running 100 octane and I wont be happy if it doesnt make some serious power.
And if it doesnt Im not sure where to look as Ive pretty much sorted every other issue that has come along.
Feel free to suggest anything - because at 10 psi I really thought it would be making more power, I guess if I pump 25 psi in on a proper tune it might make what Im looking for....but who knows until Ive done it
I dont think compression ratio and compression pressure have a direct relationship. As there are many variables that effect compression pressure, ring end gap, bore wear, ring wear, valve to seat seal etc.
So you can have two engines with 8.5:1 but both have different compression pressures.
This might be a silly place to ask i dont know, but what motor would best suit a r32 gtst with standard diff ratio (4.3)
I have a standard bore rb30 bottom end waiting to be built into a 3.1 but always wonder if i would be better off with a 2.6,7 or 8.
Both motors would be fully built with 9.0:1 comp ratios
Thanks guys
r33 racer what diff ratio are u running and how do u find it etc.
just after some info
want to run forged pistons with approx 9:1 comp ratio
and fit oil squirters
can i buy rb30 pistons or will i have to use rb25 with oil squirter cut outs
why bother with the oil squirters when people in the know ahve said u dont need them?
to quote a very repuitable shop, RIPS, taken from ww.gtr.co.uk:
Originally Posted by Sayajin
How difficult is it to put the RB26 oil squirters into the RIPPS RB30 block? Is it even necessary with forged internals?
Originally Posted by RIPS
Not required. No piston failiers, ever.
I installed the new wastegate springs in the HKS gate on Sunday. Hooked all back up and went for a drive and it was still only making .7 bar. So I turned off the AVCR, still only .7 bar. Then I plumbed the wastegate up straight to a boost source, so it had nothing to do with the AVCR, still only .7 bar. Getting a little annoyed by this time, so I totally disconnected everything to the gate. Thought I would go for a very cautious drive to see if this gate was working at all. Full revs still only .7 bar, so Im guessing ( havent had a chance to remove it ) that the valve is either not seating on the seat, or its stuck open.
There are no leaks in the intake side as I pressure tested it again yesterday.
Any thoughts on other reasons for no boost ?
yeah they finally released it, actually useful data for once
pitty it needs to much damn turbine speed to get anything useful from it
whats a realistic rpm we are talking to get a 0.70 a/r housing fast enough to make the compressor flow 1.5 bar. is there a way to mathematically work this out?
given that we know required turbine speed and pressure ratio ?
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
