202-4207 to suit RB26...
Yeah i will fit it out with the arp gear down below. Better safe than sorry :)
awesome, exactly what i've done :P
it's going to be interesting to see how long my bottom end hangs together for with the 8000rpm abuse :(
I was going to cap my rpm around the 7000 mark. I will wait and see how the turbo goes and see what the engine builder reckons as well. I felt bad revving my RB20 to 8000rpm... I just don't like big revs.
With those cams and if you run a shorter runner plenum it will most definitely want to keep making power past 7k well in to 8k. :(
I have the std GTR plenum.. ok i may be willing to rev to 7500 then :P
all you need is to not run an internal oil pump. 7500 internal, if external go 8 or 8.5 if it keeps making good power. If power dies off, then no point running the extra rpm obviously.
+1 for dry sump :action-smiley-069:
mine has std cams and inj, with a pfc and exhaust, and R34 N1s, and was still climbing at 7000 when we stopped it. 267 rwks @ 10psi.
I've found the biggest influence over where peak power lands and how power holds after peak is to use a shorter runner plenum the the std rb25 item. i.e GTR. Already being a gtr head = ftw.
Even the Rb25 head with its std cams is able to makes its peak close to 7000rpm and holds power basically flat without drop off until a shade over 7000rpm then by 7500rpm its begins to smoothly drop off.
Std runners/plenum power peaks and then drops off hard.
Mine with the port matched inlet and plenum, port matched exhaust manifold, mildly ported r32 rb25de head, valve deshroud and gt30 .82 iw made its peak 268 @ 6000rpm 15.5psi BUT it does drop off fairly hard after that. By 7000rpm its making 252rwkw. So 16rwkw over 1000rpm.
No point reving past 7000rpm BUT it does pull to 7000rpm comfortably.
Yes. :action-smiley-069:
With peak landing at 6000rpm I'm fairly happy with that so first up is a set of cams and then exh manifold and WI. :P
BUT.. I am running the GT3076 so it will most likely run out of air. They have pushed 320rwkw ish before so with WI I'd hope I could squeeze another 30rwkw out of it.
Surprisingly no boost creep BUT I do have next to no preload placed on the actuator to make use of all its travel. As a result the actuator is super lazy but it still makes good power in the early rpms despite. With the boost controller on it with my current tyre setup third gear was useless from 60km/h. :S So some work in that department also.
We found that descent suspension really helped...going from jap teins to Sks setup, some good shocks and matched springs really helped reduce wheelspin and got the power down. Suspension that actually lets the car squat can make all the difference even with poor rubber.
Looks like your well on the way to power town mate.
Joel you forgot to PM me the dyno results, and to give me a brief update :rolleyes:
Just reading what you have posted sounds awesome!!!
what is WI ?
Michael: What Teins did you have? I have just changed my suspension from "Hot Bits" to Tein-Super Streets (from Fulcrum-revalved for Aus. roads/conditions) with EDFC.
shit...i cant remember...they were your usual imported crappy shocks with super super super super stiff springs. For some reason 'HR' is sticking in the back of my mind, if that means something, possibly model or type. I think it even had street written on the sticker somewhere. Worst suspension ive ever seen.
Al....wi is codename for people in the know around here...those who have used it or are planning on using it. haha its water injection :rolleyes: Sorry i had just finished the bourne ultimatum before i came on..haha
Edited by r33_racer
TEIN HR are the height adjustable setup from a few years back - Jap spec run about 12kg springs
im running the HA with the damper adjust - super stiff with that range springs ... too stiff but still usable
chris i can assure you that for circuit racing they are by no means usable. Even with semi slicks or full slicks...hopeless.
Wait a sec...our teins had the damper adjustment screw on top too...maybe they were HA??? But they were also height adjustable.
Yep i understand that completely - HA are height and damper adj.
never had as much trouble shifting weight than with these things, but i had tannabe's in prior to these that were just as bad or worse.
been tossing up between the new super streets from Tein or the shocks and springs in the SK package.. cant decide :D (need new strut tops either way and the SK package dont supply them :O )
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
