well it took me 3 weeks but I have just finished reading this whole thread. damn what a novel...
I had a bit of a busy weekend and the RB30det is well and truly under way.
I pulled the RB30E out of the R31 and stripped it down and removed the head. Stupidly i forgot to loosen the harmonic balancer before pulling the motor.
the engine has been rebuilt recently there are hone marks in the bores, pistons look like brand new no carbon, head gasket and timing belt aftermarket and a new tensioner :D so happy times! no piston slap and all in really good condition. I am going to use the bottom end as is.
the head RB25DE R33 is also in excellent condition and will be used as is. the springs are the same as R33 turbo ones. I have drilled and tapped a new feed for teh VCT. a M10 x 1.25 thread. I have also blocked the original gallery with a M8 x 1.25 once it was drilled and tapped and used locktite.
I am using the 149 teeth dayco belt with 2 tensioner s in the standard position.
things i need to know is.
1. where the hell have u guys got your oil supply for vct fittings? every car parts place i went to did note have 1/8 npt fittings. not even pirtek!
2. What is the best way of getting off the harmonic balancer and flywheel bolts? I am guessing a rattle gun? also what size is the ballancer nut? 26mm spanner JUST to small. 28mm to big? is it metric?
3. what is the best way to remove the current engine and transmission. I removed the gearbox and motor from the R31 in one piece with a crane and it wasn't to hard. but i did cut the front of the car off first :) am i better off removing the gearbox before i take the motor out? I am guessing putting it back in in one piece will be a hell of a lot easier.
I am hoping to have it all in and started in a month. so far it has been plain sailing. this is the biggest project i have undertaken yet and i am taking my time, my power goal is only 250rwkw. this is the maximum the turbo will supply anyway and I think that is enough in a responsive r32 with torque.
any help appreciated :)
cheers dudes!
CEF11E,
I bought a 27mm socket and used the breaker bar; it was on damn tight I can't see you removing it without the motor being in the car with a gearbox hooked up. I have used a rattle gun in the past; worked well but it does have to have some balls behind it.
When I dropped the RB30DET in I removed the rb20det with gearbox attached; bolted the gearbox to the rb30det and slid it in.
This was done over a pit which made life a lot easier.
Radiator was obviously out and had a piece of wood protecting the a/c condenser.
10mins max and the motor was in position. Ahh exciting times it was. :)
2GUUP,
I've never ran with 2 down low but even with 1 low 1 high the belt is really tight to get on. Near impossible. If I were to do it again I would position the tensioner 1mm towards the centre more.
To get mine on I have to position the cam belt with the lower tensioner loose and then slide the top tensioner on. There was no way I was able to slide the belt on with the tensioner already located in place.
BUT once all on the belt still had a little too much slack which required slight pinching up.
whos done the low low tensioner setup
ive got an issue with my belt tension
its seems really really tight
ive got two tensioners in the stock position
and the dayco 149 tooth belt
mate i tried it, as far as i'm concerned it doesn't work properly due to the belt being overtight. made all sorts of measurements and turned up a dummy pulley out of plastic to see if i could get an idea of what measurement would work with a 149 tooth belt and 30mm diameter seemed right. looked everywhere for that diameter tensioner but none of them were up to the load rating. suffice to say one tooth makes a ridiculous amount of difference to the pulley diam and a 150 tooth belt had so much slack that there was bugger all clearance left when it was tensioned.
it was 'pain in my a$$holes...'
even had the NSK bearing tech guys looking for me but they couldn't find anything either so in the end i went with the hi/low setup.
my belt is 25mm wide
ive always been told if you can twist the belt 90 degrees the tension is correct
i can only manage 45 deg from this belt
people have done it so whats the GO some one help me out here
I think you mean 1mm further away from the centre to add a tiny amount of slack. Using the guide measurements mine is in the perfect location without having to tension the belt using one tensioner high and an idler low. When I install the belt I use a high tensile bolt instead of a stud and just locate the tensioner and start threading the bolt. Makes for less offset tension in the installation but the bolt does need to be well prepped with a quality thread sealer tape.
hey guys does the rb25de neo head water/oil galleries line up to rb30 bottom end??
despite vct though coz im going to keep it...
HELP!!
Mate, not everything has to be a massive drama so take it easy, think and do some more reading. Sure there is a lot to get through but it's worth it. spoolup is running a neo head so they must line up reasonably well.
How about get a head gasket and overlay it to see if it will line up?? Take photos and post them up to add to the knowledge base while you are at it.
cheers mate.. ive decided to go with an injected turbo 202 instead.. lack of funds.. should still get about 400 hp at the wheels though...
im going to keep my s2 block though to do this in the near future...
thanks for all your input, AWESOME thread guys!!!!
keep it up!!!
Guys quick question, my engine was built by Ricol Automotive and it looks like they've re-used the original RB30 oil pump. Since ive got the engine on a stand I figured I might as well bolt a new one up, but realise its too late to fit a crank collar. The RB30 oil pump from nissan is $1000 (just priced one) Can I fit an N1 pump and will it be ok providing I dont exceed 7k rpm?
if you use an n1 oil pump, change the relief spring to a std rb25 one or rb20 one. Something that runs a lower relief pressure, the n1 pump will provide way too much pressure and you will suffer like cubes said.
Edited by r33_racer
Only standard restrictors unfortunately :)
If you haven't got litres of oil in your catch can you don't really need the restrictors, just over fill the sump a bit to ensure a good supply of oil.
People have spoken of the n1 pump being brittle and more prone to damage by bad harmonics, so the n1 would probably break before the rb30 pump. A few people on this forum run rb30, rb25 without a crank collar, I think the rb30 pump will be fine for 7000rpm or maybe just put an rb25 one in, due to it having less age on it.
Edited by BAMR33
What have you done with regards to oil restrictors?
The N1 pump with std restrictors is a bad thing.
what size restrictors do you recommend? Ive got an N1 pump with collar & ATI balancer, I havnt got any restrictors yet. I have removed the old ones. why change the relief spring?
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
