If I had an RB25DE on one engine stand side by side with an RB30E on another engine stand, I reckon in one day I could have a 450 bhp capable RB30DET ready to go in the car. It is basically a bolt and unbolt exercise.
hrmm I think I may take you up on that one Sydneykid... :D lol
Sydneykid...how much would it cost to get a rb30 built? just ball park, no special bits, no turbos but ready to bolt turbs on, just a stock rb25 head non vct and a stock rb30 bottom end??
I am so in two minds now about building an rb2.2....I'm sure it would be nice and all but couldn't cut it even compared to a stock rb30 with a stock rb25 head and a turb to match....
If its not too much trouble for a ball park price...,
Thanks...
Ender..
If you were to grab a stock RB30E NA bottom end that had low kays and bolted on the RB25DE Head you would be up for maybe 2k inc. an ecu reprogram. I'm going off a head is $800-$1000 you fit it your self with the gasket kit which i'm guestimating a max of $300 plus an ecu program worth around $500.
2K should do it. If you have to use the RB25DE Plenium chamber as the rb20det one doesn't fit apparently. The RB20 Exhaust manifold is fine however. A dump pipe mod may also be required.
I am wondering for cost factor would it be possible to use the RB20DET injectors on the Rb25DE Head?
I was gonna get someone else to do it, no time at the moment....
What about the farication required? new pulley placement, will my alternator and p/steer pump bolt straight on?
I have an rb20det fuel rail and 550cc injectors, was wondering if I could use these, on a non vct head,
If I use the standard exhaust manifold off rb20 then I could use any TO3 flanged turbo right??
Cheers,
Ender.. All the RB bottom ends are the same or similiar should I say everything bolts up the same.
You can use any TO3 flanged turbo.
With regards to the injectors.. That is what I would like to know as I have larger than standard items.
Hi endewr, last RB30E/RB25DE cost as follows;
Buy RB30E $160
Buy RB25DE $1100
Sell RB30E head -$100
Sell RB25DE bottom end -$400
Sell RB20DET complete -$500
Commondoor Gasket kit $180
Commondoor Rings $80
Commondoor Bearings $120
Balance $220
Hone $120
Assemble $350
Fit to car $400
R33 GTST turbo & Ex manifold $400
Series V Turbo RX7 Injectors $520
Tune R32 Std ECU $800
Total $3450
We used an RB20DET inlet manifold with the RX7 injectors and retuned the standard R32 ECU to suite. Car already had a GTR intercooler and split dump exhaust. We got the turbo mildly hi flowed by GCG soon after and car made 260 rwkw with a Z32 AFM at 0.9 bar. Last time I heard it had done 50,000 k's with only regular servicing.
It didn't feel like a turbo car at all, it just had linear power from idle all the way to 7k rpm.
Hope that helps
Hi Joel, the RB20DET gearbox seems OK to around 260 rwkw with an RB20DET driving it. The RB30/25 engine had a lot of torque so I expected the gearbox to die, but it seems to have lasted, done 160,000 klms that gearbox. Changing to an RB25DET gearbox is pretty easy though, and if you trade in a good RB20DET box, not that expensive. If you are going over 300 rwkw then it is essential.
Yep, standard pistons, no block based oil squirters, they are in the rods on an RB30. They work OK, as long as you change the oil and filter regularly.
Hope that helps.
Hi matlowth, TRY09 (or is it TRY08 now?) runs standard GTST driveshafts and a standard viscous diff centre and ratios (crown wheel and pinion) as well. I know it's an auto (not a manual), but 26" tall drag slick and more than 400 rwkw. I for one am not worried about my GTST rear end handling the power.
I am not sure about tailshafts, but I have never seen a broken Skyline one, they wear out uni's slower than most high powered cars. Thanks for the tip though, I'm gunna check the sizes of the GTR tailshaft compared to the GTST one.
Hope that adds to the discussion
What gearbox does try09 use? I'm tipping that if you want to go any more than 320rwkw in a GTSt then you'd need to look at gearbox upgrade... and that will be very expensive! Has anyone tried mating a supra 6sp up? do they handle much more power? Or are you better off spending the money on a better gear set for the GTSt gearbox?
..here is some help... my car "click here to view " had a rb30/25 conversion done. it had forged pistons, i thought it had shot peened rods but it didnt.. it made a max of 566rwhp and was driven on this engine at that hp for 1.5yrs everyday before an injector failed which caused the engine to seize. tony rigoli asks 4k for the complete conversion drive in and out with new head studds and some other sh*t. personally i think the rb30 is one of the best bottom ends every built by nissan.
nice... but i thought moving the throttle body like that on the plenum would mean that cylinder 6 (closest to the windscreen) runs lean (or is it rich) as iit doesn't get as much air. Has anyone thought of doing twin throttle bodies?
Is the Rigoli drive in drive out based on the stock bottom end or do they put in forged pistons and better rids too? and do they pull the engine out and put it back in, bolting the head on etc? or do you give them the block crank and sump and they just build the bottom end for you? meaning that you have to put the head on and put it in the car...?
not too sure i think its leave your car complete pick it up complete ready to drive but thats the price he quoted me with forgies and he said the plenum that i have has bench flowed and apparently flows much much better then standard. best to speak to rob at there new work shop in smithfield.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
