Wow what a power curve :)
What do you think you'll make with the 3076 at higher boost Al?
I'll be very happy with anything over 300rwkw.
My aim was to have as much power as my previous set-up, with more torque and response - I have already achieved that with the run-in tune :D
At 20psi, with a final tune, i may see 310-330rwkw, but time will tell.
Top work Al.
What do you think? Feels like a BIG NA with a nice top end? :)
Pretty much. Feels damn great, especially the torque :D
Joel, just compared your graph to mine (on the dyno comparison web page) and you have more midrange; is that your final tune and how much boost are you running?
Has anyone fitted a high energy HE2112 VL 3.0L Commodore Super Pan $458.53* into a 32 without having to use a custom made front sway bar?
http://highenergy.com.au/index.php?module=...5539231984-1177
A few pages back, Al had problems with his HE8124 Pro-Circuit 3.0 VL/Nissan, 4 Gates, 7L, P/Up clearing the sway bar.
You need to replace the front swaybar bar for both the 6.5 litre and 8 litre HE sumps. I designed the bars for them and for dry sump equipped RB's a couple of years ago. Quite a few sold now, for example Giant used one at Tsukuba last year. PM me for details.
Cheers
Gary
Al im sure you've probably mentioned this somewhere before, but what exhaust A/R are you using? 1.06??
0.83
I chose the components to achieve great response, as i like to use the car for motokahnas, soon to do a few hill climbs and a few track days.
Big power was never my goal :P
Pretty much. Feels damn great, especially the torque :P
Whats the link I've lost it. :)
Mine isn't the best comparison as it runs a shorter diff ratio 4.363:1 + due to the lazy actuator it wasn't making 15psi until 4500rpm on the dyno. ~11psi at 3000rpm.
I had a cheap ball/spring bleeder on it which was taken off due to the rb20det gearbox; it brought boost on MUCH earlier; we saw 19psi by ~3200rpm which tailed off to 17psi by peak power where we saw a peak of 285rwkw. So 17psi 285rwkw.
The curve was a bit wobbly due to something strange going on. Shaun said it was airflow related and most likely related to the small cams (240dur in 232dur exh). I have since measured the intercooler piping which I've discovered the OD is only 50m :S
So 2" IC piping I'd say is the issue. I had it fitted ~6years ago when 200rwkw was the now 400rwkw. :)
I'm sorting an FMIC for it now + ebc and baby cams all to go in so fingers crossed with the std exh. manifold we can push 300rwkw out of it.
Would love to get a hold of a hks cast manifold :)
http://sau.garagespank.com/login.php
Mavric had a HKS manifold for sale, not sure if he sold it yet :D
Whats the link I've lost it. :thumbsup:
Would love to get a hold of a hks cast manifold :(
Hi Al
that's a great result. also the under bonnet shots show off a lot of neatness eg the airbox. very naace, i like. whats the small rubber tube coming to/from the airbox?
cheers
Thanks mate. As much effort was spent on making the bay look neat as making the engine strong and reliable.
The hose to the airbox is the "breather hose" from the catch can, in the top right corner. Just like factory, it is plumbed into the intake. The catch can is properly baffled and also drains into the H.E. sump.
For some strange reason i am particularly happy with the fitment of the washer bottle inside the guard and the snorkel coming through into the bay.
that's a great idea. missed the snorkel first time, i did a similar thing on a Jensen Interceptor with a commodore bottle and was equally pleased because it worked so well. can i ask what it comes from?
Well mine is back on the road; but in run-in tune. :)
Couldn't be happier, i keep grinning every time i press the GO peddle.
Below is a few pics of the completed engine bay and the run-in tune. The boost is very responsive, and that's only controlled by the actuator (no bleed valve, EBC or restricters) Once i have completed 1000km, it will be wound up to 20psi, then the fun really begins :thumbsup:
looks fantastic mate!
Wish mine was on the road, just waiting on the workshop to pull finger from arse and get it done...
I pick mine up late next week :) I didn't realise how expensive it would be. My RB20 cost 4.5k and i have spent 12k just on parts with the new engine and still have to pay for the machining. I did go a bit crazy with name brand parts tho :thumbsup: Check out the relief work to clear the cam lobes.
post-24062-1205204800_thumb.jpg post-24062-1205204815_thumb.jpg post-24062-1205204875_thumb.jpg
With regards to previous page where i asked about Engine management. I dont mind the sound of the Autronic. Thanks guys.
My pistons arrived today.
For those that dont know I asked to have them made for a pin diameter of 22mm. When I got them they were 21mm. I also noticed that the small ends on my rods were 1" thick over the standard .857" for all other aftermarket (and stock) connecting rods so nothing really suited. I sent them back to CP. They were remade within a week and delivered to my door today at no extra cost.
I am so happy to see that my rods now fit!
I think it came off a Honda Accord or maybe a Prelude. Not too sure as my mate got it from his father's wrecking yard and he just searched through a stash of different water bottles.
Al, Is that just paint on the intake piping/intake plennum?
Nope...:P
All pipes, plenum, brackets, catch can, cam covers, power steering reserviour, etc have been powder coated.
RB120WHY: Looks like it's going to be one very aggressive engine, keep us posted :)
It's taken 12-13 months, but most the delays were due to other w/shops
ie: - 3 months for the block machiniest
ie: - 17 weeks to finally get a good sump H.E. -> ETM -> H.E.
ie: - 5 weeks for the engine bay to be painted
etc..
While i was waiting it was hugely frustrating, especially missing all the SAU-VIC events and cruises, but i honestly couldn't be happier with the result.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
