What an awesome thread! I thought that 10 page pdf was impressive but damn!
Im building an rb30/25 and have got the block almost ready to put into my 32 coupe. The parts used in the block are as folows:
-Rb30e block
-Factory crank (re balanced)
-Wiseco forged pistons (40thou oversized)
-Forged eagle rods
-N1 oil pump
-ACL race bearings (big ends and mains)
-ARP bolts
The block was honed bored decked and acid dipped and now is back in my possession.
Ive bolted up the mounts, sump, water pump and flywheel and it is about to go into the car. BUT only recently ive heard i should restrict the oil flow to the head using TOMEI gallery restrictors so the blocks oil isnt pumped all to the head.
Is this a necessary and recommended mod?
My next querie is will I need to replace the factory rb25de valve springs to cope with big boost? With the block ready to make mumbo i dont want the head to restrict me too much!
Any tips would be awesome
Cheers xsv 32
Um thanks but im from christchurch new zealand lol. Anyone know how to tell the difference between a r32 and r32 rb25de head??
the r32 doesnt have vct and has smaller ports afaik, the springs should be the same as any rb25 non neo (aftermarket wise)
Edited by R34GTFOUR
R32 RB25DE non VCT has different springs to R33 RB25 VCT - they are same as RB20 or RB26, equal length on both the ex and in so you can not use R33 ones.
Awesome. Im pretty sure its a r32 25de head which is perfect bar the weak springs...
Was just masking up the block to paint and discovered that the engine builder had already put oil gallery restricters in for free! SCORE. :)
Any suggestions on the best gasket to use? The block and head have only been surfaced and not skimmed so what thickness should i aim for to get around 8.5:1 - 9:1 compression.? Also the pistons are oversized about 1mm...
Based apon my thread named "Which RB engine combo?"
I'm looking at building a performance RB motor out of the bits and engines that I already own.
Here is the list;
RB30 engine (non turbo) complete
RB25DET complete (worn rings)
RB26DET rods and pistons (only)
Do I start with my RB25DET engine and work it or the RB30 and work it and say put the RB25DET head on it? Surely I dont have to use the RB25DET head on the RB30 to get 300plus rwkw? I know the RB26DET rods and pistons fit into the RB25DET but do they also fit into the RB30 crank and block as they are all the same bore size? Im not wanting to spend to much money but prepared to spend some money of course for extra performance bits. I'm wanting to get as much hp as possible and still use pump fuel and have boost under 20 psi.
Any other suggestions?
The engine will be going into a 1970 fibreglass car (total weight 750kg) that has no loom for these motors so I may consider a carburrettor version of the above or obtain the appropriate loom/computer.
________________________________________________________________________________
My latest thoughts
Ok...why cant I just use a standard rb30 head (maybe port the head a little) on my rb30 block? What benefit am I really going to get putting my rb25 vvt turbo head on to the rb30 block with all the head ache and modifications needed to do so?
Surely the rb30 head with some work done to it can do the job as well or better? The rb25 vvt turbo head is probably worth $700-800 at then I still have to change 2 cams in it costing probably $1500 plus in total. I only have to buy 1 cam for the rb30 head?
So...the rb26 turbo pistons fit on to the rb30 rods and can then be used into the rb30 block. What compression ratio will this give me using the rb30 head?
Edited by The Ant
The idea of the 3ltr is it spools a larger turbo quicker and makes more power 'under' the 300rwkw curve.
An rb20det can make 300rwkw but it will be as laggy as hell and have bugger all mid range.
The rods fit but the pistons will NOT unless you also run with the rb26dett crank.
The rb26 gains its additional 100cc by using a slightly longer stroke and pistons with a reduced pin height. Drop 'just' the rb26 rods and rb26 pistons in to an rb25det and the comp ratio will suck not to mention the piston sitting down the bore. So definitely not a wise move.
No the rb30 has a longer stroke and rod length. So no. :blush:
You can but the rb30/25 will ALWAYS make the power easier and be much more fuel effient and friendly to drive.
Start working the sohc head with big cams to get near the stock flow level of the rb25det and fuel economy/driveability suffers.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
