I assume from your statements that you are running a D-Jetro PFC (MAP sensor)?
To run it on a standard ECU you will need to throw an AFM in there. I will also guess that it will max the standard AFM pretty much straight away and run in R&R most of the time..
Hmm, no, just go the regular RB25DET AFM and standard RB25DET PFC! Just don't have the boost sensor like standard '33's do. :D
It's actually a pretty standard setup, stock turbo, stock injectors, stock sensors. Makes about close to 200kw at 14psi. I might give it a shot and take it somewhere for them to check the a/f ratio, etc.
Hmm, no, just go the regular RB25DET AFM and standard RB25DET PFC! Just don't have the boost sensor like standard '33's do. ;)
Hmmk, don't know much about 33's, AFAIK the boost sensor was purely to operate the indash boost gauge.
That power isn't bad, I've got a 25 turbo on my 30 and it makes 183rwkw @ 12psi but really dies in the ass up high, about 5800rpm it chokes up bigtime :D
So as per the guide is 33mm and 17.7mm the correct distances to locate where the top tensioner will go? I thought i read somewhere on here probably in this thread that that spot was infact a few mm in one direction?
Thanks fellas
I'd bring it across another mm or 2 away from the centre. Mine needs no adjustment atm once the belt is on and a little extra space would be nice.
[edit] gave the wrong direction [edit]
Im pretty sure your right, as only the R34 has any mention of boost sensor to ecu.
:huh:
I thought the map sensor sig does go to the ecu on the r33.
How else does the ecu know when to switch the ground on the boost control soleniod.
:D
You're welcome. There is space there and with the belt I got (which is the recommended one in the guide) it was a tiny bit too tight initially. Tension is perfect now but it needs no adjustment.
I noticed some tool in another thread that thinks that 30 hybrids need to be absolutely right...well more that it is very easy to screw up the job and have an absolute pig of an engine.
Anyone having those problems?
I'm not but I can't find the thread so further assistance and support can be offered from the other experienced lovers in here :(
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
