I assume from your statements that you are running a D-Jetro PFC (MAP sensor)?
To run it on a standard ECU you will need to throw an AFM in there. I will also guess that it will max the standard AFM pretty much straight away and run in R&R most of the time..
Hmm, no, just go the regular RB25DET AFM and standard RB25DET PFC! Just don't have the boost sensor like standard '33's do. :D
It's actually a pretty standard setup, stock turbo, stock injectors, stock sensors. Makes about close to 200kw at 14psi. I might give it a shot and take it somewhere for them to check the a/f ratio, etc.
Hmm, no, just go the regular RB25DET AFM and standard RB25DET PFC! Just don't have the boost sensor like standard '33's do. ;)
Hmmk, don't know much about 33's, AFAIK the boost sensor was purely to operate the indash boost gauge.
That power isn't bad, I've got a 25 turbo on my 30 and it makes 183rwkw @ 12psi but really dies in the ass up high, about 5800rpm it chokes up bigtime :D
So as per the guide is 33mm and 17.7mm the correct distances to locate where the top tensioner will go? I thought i read somewhere on here probably in this thread that that spot was infact a few mm in one direction?
Thanks fellas
I'd bring it across another mm or 2 away from the centre. Mine needs no adjustment atm once the belt is on and a little extra space would be nice.
[edit] gave the wrong direction [edit]
Im pretty sure your right, as only the R34 has any mention of boost sensor to ecu.
:huh:
I thought the map sensor sig does go to the ecu on the r33.
How else does the ecu know when to switch the ground on the boost control soleniod.
:D
You're welcome. There is space there and with the belt I got (which is the recommended one in the guide) it was a tiny bit too tight initially. Tension is perfect now but it needs no adjustment.
I noticed some tool in another thread that thinks that 30 hybrids need to be absolutely right...well more that it is very easy to screw up the job and have an absolute pig of an engine.
Anyone having those problems?
I'm not but I can't find the thread so further assistance and support can be offered from the other experienced lovers in here :(
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
