Anyone care to tell me how to get my standard dash tacho working? Im running Autronic SM4, do I just interface the tacho wire from the Autronic to the wire from port 7 on the standard ecu? Surely I cant be the only one to encounter this when not using standard ecu. Cheers!
ACTUALLY I STUFFED UP.
Sorry, I've been hammered on morphine for the last 2 weeks. It has to go OUT 1-2mm to ease the tension a little.
Correcting other post now.
Sounds like your back is still giving you trouble; sorry to hear mate :teehee:
Best to move back to Melb, it's nice and sunny down hear ;)
PS: I also agree with Geoff on the tensioner location. For the new block, we have moved the bolt hole another 2mm across, away from center.
Thanks for backing that up al cheers.
Now ive rung nissan to get a VRS kit for the Rb26 head but nissan want to know if it is before or after the 3/93 with the latter option being cheaper. I havent heard too much talk on here about needing one or the other so im guessing both are the same?
thanks fellas
Just out of curiosity what would be involved in fitting an RB25/30 to a 180sx???
A rough price estimate would be great too if possible...
Thanks.
Front face plenum, lower the mounts as discussed in this "small" thread, move the power steering lines if needed, put a small love bump in the factory bonnet or get a aftermarket one.
Price.. depends how far you go..
I started mine at the start of this thread and I am only just now doing the final touches now. :D
Question about the PowerGrip belt and the Harmonic...
when i fit the belt it sat wonky like the pic below
but with more tension it sits in fine.
Gates state that they supply 2 types of belt, a standard one and the one above which is their "performance" belt.
Not sure if its a case of this belt requires more tension than standard.
Has anyone fitted the 1200 8MGT (says gates on the belt not dayco) and run the car with no issue?
There's previous posts about it but no result.
Thanks
Edited by silver gts-t
If you look at the 30 head you would notice that the way the valves are arranged they sit on one side for the first three and the other side for the last three. In the end its just cheaper for Nissan to make the one set of pistons with the cutouts there rather than two separate designs.
Anyone??? Surely I cant be the only one who needs this info can I??????
wat parts would you need to make a 30/25 combo around 300rwkw and how much roughly
cheers
Tried searching? or trolling through the RB30 threads? oh.. maybe even look at the RB30 dyno results thread! shock horror!
looking at my rebuild kit today something struck me, why did nissan make the pistons to suit a 4 valve head? By that i mean the piston has the cut outs for 4 valves.
Was nissan keeping an ace up their sleeve :thumbsup:
what pistons are they and price if you dont mind
I've had no problems with my standard tacho, using an aftermarket ecu (wolf 3D). Are you sure something else isn't farked up? Have you tried your cluster or ecu on another car?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
