I'm using the 25de cams, fine for now and they do something at about 4500rpm.. even though I'm making full boost by 2200rpm it pulls harder again over 4500rpm... will be interesting with the bigger turbo.
RB20DET specs are: in: 240deg, 7.8mm ex: 240deg 7.8mm
RB25DE (R32): in: 240deg 7.8mm ex: 232deg 7.3mm
RB25DE (R33): in: 240deg 7.8mm ex: 240deg 7.8mm
RB25DE (neo): in: 236deg 8.4mm ex: 232deg 6.9mm
wasnt sure which RB25 you meant so i thought id post up all 3, got the specs from the RB30 guide on the forum
So going by this RB20DET's are prob the way to go
The RB20DET cams require a little fiddling with adj cam gears to make the most of them.
When I ran the RB25DE cams they made good power once a larger turbo was dropped on. The RB25de centerlines do suit the rb30 with a larger turbo better than what untouched rb20det cams do.
Std cams mine made peak power at 6000rpm and torque peaked at around 3500rpm. STD and VG30 turbo peak power was at 4400rpm that held on flat until 4800rpm for the std turbo. The VG30 turbo was pretty much the same but held on to peak until ~5500rpm where it would nose over hard. I suspect valve springs were playing an issue with high back pressure on the exhaust side.
In comparison to RB25DET's with their VCT and the same turbo same boost etc on the same dyno mine was making ever so slightly better power. Which is most likely as a result of the head that had been ported polished.
A set of cams saw mine pick up close to 25rwkw on the same boost. It now allows a heap more ignition timing and is no where near det as it was when running the std cams. It makes the power easier and is not as highly strung as it was with stock cams.
^^ +1
Should be interesting to see how my custom plenum goes.. if that guy can make 370rwkw on an RB20 with the same plenum setup I think it should do fine! also cost half what an off the shelf item does :(
hey im in new zealand and im just wondering where i could get some tomei oil restrictors from? I'm thinking about putting 1.5mm oil restrictors in both the valleys which leads me to my second enquiry, im just wondering if there is anywhere in new zealand where i can get a n1 oil pump as im in Hamilton and have even tried Auckland without any luck. If anyone could help me with either of the issues it would be much appreciated cheers.
Hi mate, im in Hamilton NZ as well and have just about finished my 30.
Ring Rob at RIPS and get a 33 or 34 stock GTR oil pump. He will have plenty of those lying around at a pretty good price. He should also have some oil restrictors that you can buy, or otherwise just one made up by an engineering shop. Should be pretty easy.
I got mine (before i knew how simple they were) from nengun.com.
There is a guy pure_methamphetamachine on the NZPC forums who might have a brand new N1 one sitting at his place as well. Simons his name and hes a good sort.
Edited by SirRacer
Nope, I feared they would want me to get it engineered (as it's a 50% capacity increase) but they didn't. I don't have a big highmount turbo hanging off the side so that probably helped but I do have bigger everything (brakes, clutch, gearbox, tailshaft, diff) so it wouldn't have been much of a drama if they did want it engineered, only $$. They did take it for a drive though and must have felt everything was acceptable *shrug*
I think ADR's limit an unengineered swap up to 25% or something silly like that so if there were legal problems, it would be more legal to drop a 30 into an R33..
Edit: oh I did get a REALLY nice inspector at the pits tho, he really liked skylines and thanked me afterwards for having a drive of my car :(
Edited by bubba
I'm using a large body 3" Hi-Flow Metal Cat...
Main reasons for using one:
* a bid to muffle the sound a bit as the 3" straight through pipe was a tad bit loud (understatement)
* to stop myself and other occupants from getting high every time we go for a drive, massive amounts fuel fumes before cat (parched throat, stinging eyes etc), none after
Cost of the cat was quite reasonable too although I got other things done at the same time.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
