i'd like to use the RB20 plenum too for the "stock" look
along with the RB20 cam valley/ignitor cover
Nissan 2000 24 valve :) :)
can the RB30t water and oil pumps be used? would these be better than the 25t pumps ?
also if i had a bare block RB30 where would i fit idlers and tensioners? what sort of $$$ are they worth ?
*bring back the old thread :) *
  • 4 weeks later...
I saw a article in zoom where they had a worked RB26 with cams and huge turbos etc, they then changed over to a RB30 bottom end. Thats all they did, plus a re tune. They left all the other hardware in place. So it is a good scientific example because the only variable that changed was the bottom end.
The engine did not just get some more bottom end grunt. It got more bottom end and shit loads more max power as well, all at the same boost levels.
So engine analyzer programs aside, in real terms the RB30 conversion will shit on the smaller bottom end in power and torque. Sure, it won't rev to 10,000 RPM but it won't need to becuse it will out power the smaller engine at much lower revs.
Nope, nothing different cept bottom end not even boost.
I dunno on the dyno it had fullboost when being held at 2300rpm
On the road i really couldnt tell you as i wasnt watching judging by torque its pretty much full boost at 3000rpm in ramp mode.
4th gear is roughly 35 rpm to every 1 kph i believe
depends on the tyres u are running.. :mad:
I can see how a 4.11 is pretty much required for a RB30.
If 1kph = 35rpm the RB25 made peak power around 6000rpm and the RB30 made peak power around 5200-5300rpm.. That doesn't sound right. Unless the RPM is out 500-600rpm.
Doesn't the RB25 make peak power around 6500rpm?
If that assumption was correct then the RB30 would be making peak power close to 6000rpm which is what i've heard previously.
So what did you have done to the short motor?
Forged pistons etc?
JNR24 I think he is talking about the RB20 Turbo oil pump?!?!
If so that will fit and flow enough.
The R33 GTR + oil pump requires an Adaptor.
The R32 GTR pump fits but apparently has problems with some thing cracking.
The cracking maybe due to rev's however so it may not be a problem with the R32 GTR pump on the RB30.
?!?!? Unless I am wrong.
Joel - when you just increase the capacity of the motor without increasing the volume of air going to it, the point of peak power will move lower... That's why you need a bigger cams, valves, turbo's, etc to make the most of a 3ltr motor.
But for a street/track car - that torque curve and power curve are ideal!
matt
Forged pistons etc?
The NA RB25DE Cams are supposed to be slightly more aggressive compared to the RB25DET cams, not to sure but thats what JMS said?
Sounds good Matt. You can definately see on Raists power curve where the flow restriction begins.
That power dip will be slightly associated with tuning.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
