bigmaxy: it would work and be a true straight line monster.. but you're going to have problems with diffs, gearboxes and the like using much of the aussie R31ness.. and I wouldn't want to be cornering in an aussie R31 with 300rwkw or so on tap ! I have both an aussie R31 and R33 turbo, and the handling differences are pretty large.
I would probably just go for a straight swap RB20DET or RB25DET in there. No need to pull apart an engine and should be fine with stock internals for the power you want of around 250rwkw. That way you can just drop it in.
If you're really keen RB31DET is a monster, but in an aussie R31 i wouldn't be bothering unless you wanted a drag car, as it will probably throw you off at the nearest corner.
Hi, I have afew Q's
Awesome post, but a little to long to read on my lunch break
I am interested in performing this transplant into my r32, what is the total cost of the motor + extras
Do you need to perform any custom mods to fit to an r32, mounts, crossmember etc
How much heavier is the rb30/25det than the rb20det, will i need to upgrade suspension brakes, is it heavy enough to upset the handeling?
Hey guys, im running a GT3040 with the .82 AR axhaust.
People keep telling me it's going to be to small on my RB30 and run out up top?
Will I get the 500HP at the engine I want? Or is it going to be too small??
If thats the same as the 2.41/3.22in comp wheel 550hp GT30 on Ray Halls site, then yes, it looks like it'll give you your 500hp at the engine. I would have gone with the 1.06 exh AR too if I as using a GT30. Run it as is and see if its what you want. A exhaust housing swap to 1.06 is relatively cheap if it doesn't work out.
I'd be interested to see how a 1.06 exh AR 600hp GT30 compares with a 0.82 AR exh 620hp GT35. The GT35 is the turbo I'm considering using.
Gradenko.. stay tuned because i have a GT35r with 0.82 exh housing... hopefully it will spool up quickly and hold good torque throw the entire rev range, tho i thought it might be a bit too small to reach high 400 low 500hp@wheels
Well I have the GT3040 to try.. my manifold has been modded to fit it.
When you say boost to fast? Do you mean it will hit all of a sudden rather than more gradual with a bigger exhaust housing??
I have a T88 33D in the garage... but I think I will like the smaller turbo a little better :P
Laying them next to each other though, the bell mouths are the same size... haha.
yep,
Boost comes on EXTREAMLY sharp, and fast. :P (boost comes on with allmost same response as a supercharger charger, except without the linear boost rate of a charger.)
Gees... T88 33D would be diffrent, provided you have a 8K auto with transbrake and 12" slicks. :(
Not sure yet, will get it weighed when it's actually finished..
Probably not a hell of a lot lighter than a Skyline by the time it's all togethor.
RB30 + Bar and Plate cooler, and all the other turbo parts really add up in weight.
Have got fibreglass front guards and a carbon bonnet for the thing so that should help...
Yep, that's what I have found with the 1 X RB engined Silvia I have weighed. The guy wanted to do it 'cause it weighed 250 kgs less than an R32GTST Skyline. Then he added the Skyline engine, front subframe, gearbox, tail shaft, diff, drive shafts, brakes, hubs, rear subframe, wheels, intercooler, oil cooler, radiator etc. Bingo it now weighed the same as an R32 GTST Skyline. It was a total waist of time, money and effort.
Now that's a sample of 1, maybe not representative. Let me know what yours comes in at.
i have been quoted ~$770 i think it was...
Std rods with Lininished, resized, rebushed small ends, arp rod
bolts fitted approx $670, $100 for new bearings
I have also spoken to a friend who said it cost him $250 for a set of 6 rods to get shot peened..
hmm
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
