hey guys
I've just installed a boost gauge onto my r32 gtst which has pod filter, high flow cat ,and cat back exhaust. Now i know that when u put the exhaust on u can see upto around 10psi.
The thing is my boost gauge tells me i have around 11.25 psi, when we all know that the stock wastegate actuator is 10 psi...so is it my guage or am i missing something here
i have t'd the gauge off from the stock boost gauge line.
anyone know anything about this?
https://www.sau.com.au/forums/topic/154223-just-installed-boost-gauge/
ahh...i see. Yeh i think ur right it must be a "rough" figure mixed in with a lil bit of boost gauge innaccuaracy.
just by the sounds of it tho on these forums people were saying its a definate 10 psi actuator, no more no less.
there u have it people, i have been running 11.25 psi (at least) on my stock r32 for at least 1.5 years and the turbo hasn't gone boom!
I have one of these on my R33 it seems to run 9psi to 5000rpm then 11psi till redline used to do the same thing on the R32 it came off. Any ideas why and yes the 2 stage boost soliniod has been disconnected
cheers
i had the same thing happen to me, only put a pod on my 32 other than that was bone stock it was running 11, kinda dissapointing. then when i put the cooler on it went to 12psi. im not looking forward to the full exhaust next week.......
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
