Does anyone know much about the tests that you get done at Botany or Penrith?
Mine is booked in for Botany in the morning and I was wondering if leaning the PFC off heaps would make it better or worse... Anyone have a Idea?
Would using different fuel make a difference? Should i use BP98 or Mobil Synergy or Optimax 100 or even the E10 fuel thats available?
Has anyone passed this test with a Power FC with huge injectors and a topmount gt35r or something similar?
Would be good to see how bad or close my car is before i go spending lots of money to get it right.
I got stock cams and cam gears and just put a Xforce highflow 3" cat on it
Any ideas welcome!
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/155081-emission-testing-modified-skylines/
  • Replies 185
Depending on what year it was made, emissions change , you will have to pass the emission test for the time your car was made .
If its post 95 my guess is you will not pass unless its very close to stock .
Edited by wrxhoon
any ideas what fuel to use Jerry ?
I would use the 100 ron from Shell, because it has ethonol and it may help.
The last time I took a car for enissions test , this fuel wasn't available so I used normal 98 ron.
If you can get your hands on a new ( or near new) compliance cat , i would use that as well .
To be honest with you , I dont like your chances with your current set up. If I remember correct your car is 95 model and that mekes it harder, earlier models would be slightly easier to pass.
Good luck and let us know how you go. Give me a buz if you like as I have a tip fpr you but I dont want to put it on here for obvious reasons .
This is just the first step to see how much my car is out before changing anything to pass for engineers certificate.
No defects or anything so im being pro-active instead of re-active atm
Give Matt (aka Hitman) a call. I think he helped Mona sort out an emissions test last time.
Are you going for a test just to check, or is it for engineering cert / EPA?
it kinda makes sense to use a better burning fuel.. maybe even advance the timming abit so that it burns all the fuel? retarding the timming would be the reverse? this makes sense in my head duno bout on paper.
well the question for me now is should i use the optixmax 100octate fuel thats 5% ethenol or use this e10 blend stuff that is available thats 10% - the 10% will burn a better emission but its only 95 octate and i wont be able to run it as lean with the same amount of timing.
What to do...
This is what i found about e10
Emissions outcomes for E10
In general, E10 can be expected to yield reductions in the following emissions:
carbon monoxide (CO);
exhaust hydrocarbons (HCs);
particulates;
oxides of nitrogen (NOx), (in some circumstances);
greenhouse gases, depending on the ethanol production process; and
known carcinogens, such as benzene.
However, some increase in other known carcinogens, such as formaldehyde, can be expected.61
So it does decrease nox which is one emission they test for.. now to look on the site to see if they test for formaldehyde - whatever that is...
particulates;
This is what they test: THC, NOX, CO and CO2. They will do 2 runsa the first is a warm up run , most cars will fail this and then they do another run.
Cheers Jerry..
Thanks for your advice its all sorted... and i decided im going to run the shell 100 because its the best of both worlds.. its got 100 octane and 5% ethenol.
I really dont think there is much chance of passing but i need to start somewhere.
So no one here has passed there modded skyline with intercooler / plenum / top mount and 700ish cc injectors with a power fc and gt35r before?
Found this on the gov emissions site. which basically says that the NOX level is increased which is what most skylines fail on. So i am going to run normal BP98 fuel or Synergy 8000 after i do more research on the 2 i will decide.
Hydrocarbon emissions decreased as higher percentages of ethanol were added to the fuel:
at 10% ethanol, HC emissions decreased by about 18%;
at 20%, HC emissions decreased by about 22%; and
at 40%, HC emissions decreased by 45%.
CO emissions were consistently lowered as higher levels of ethanol were added to the fuel:
at 10%, CO was reduced by about 18%;
at 25%, CO was reduced by over 30%; and
at 40%, CO was reduced by over 40%.
NOx emissions increased substantially with ethanol volume:
at 10%, the NOx emission increase was about 10%;
at 20%, the NOx emission increase was about 14%; and
at 40%, the NOx emission increase was about 20%.
It should be possible to get it to pass, P.S. make sure your closed loop is enabled on the hand controller. They dont do power runs or anything like that, its all mid/low throttle stuff. you will need to have the cold start/warm up enrichments well calibrated to pass though. When i had a car tested, they practically made it pass by telling me where to make the adjustments, and then did the second test. PS when i worked at chiptorque, we got the horsepower hero VK commodore with 440 rwhp to pass, although the cats almost killed the motor.
Closed loop on my car made the thing run rich as all hell!!! it was running into the 13's etc etc
This is a good idea though if it does fail i will ask them for a run with closed loop on.
I was going to suggest the higher ethanol content, run low and fill up with an emergency 5 bottles of Recochem metho 95% ethanol. Do the test, pass with flying colours, quickly get to a servo and fill up with 10L of fuel, run it down to dilute the ethanol, then fill the tank up per norm.
I can't see it hurting if done over the course of a couple of hours, I've done this with a corolla with a 4AGE, I ran close to pure ethanol in an emergency and it actually ran beautifully.
failed! but it was a good result for the first run - its not even twice over the limit for nox - nox was 3.45 which should be no more then 1.93 and the THC was 0.99 when the limit is 0.93 and CO was 2.4 where the limit was 9.3
So the engine is running too lean and its very close to passing. I am thinking about doing some more tweaks and give it another go or get my mates dad to tune it with his 5 gas sensor
ohhh and my car gets 11.9 litres per hundred economy!!! thats pretty good for 400rwhp!
Edited by Guilt-Toy
He also said that my car has some kind of vapor leak - and you can smell it too so i gotta get a smoke test done to fix that because in the room it was reading 23 where when there is no car in the room it should read 0 and a total new stock car reads 1 - 2 so something is leaking vapor somewhere
Very interesting....
And great to hear. :laugh:
I can often smell a little vapour from mine. I have no idea where its coming from.
Possibly from the seal in the boot where you remove/install the fuel pump as it has been out a couple of times.
Maybe old fuel hose near the petrol tank? If I place my nose up against mine I can smell fuel. :S
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
