What do you get when you bolt a supercharged 1,000bhp engine, hitherto found under the bonnet of a four-wheel-drive monster truck, into a home-made motorbike chassis?
Most people would probably say “trouble” or possibly “a ride in an ambulance”. But for engineer Nick Argyle, it seemed the obvious thing to do when tinkering with some bits in his garage one day.
Argyle had built his own monster truck some years previously before selling the chassis but keeping the whopping 8.2-litre Mopar V8 engine. Lacking the space to build another truck, he decided that the ideal home for the supercharged powerplant would be a two-wheeler.
Called the Rapom V8, the result is the most powerful road legal motorbike in Britain, with between 1,000 and 1,200bhp depending on the boost from the Littlefield supercharger. That makes the Bugatti Veyron, the fastest car in the world with 987bhp, look rather tame.
And if you thought your neighbour’s SUV was a gas-guzzler, the Rapom consumes a gallon of pure alcohol ever four miles. Fortunately Argyle only uses it for the 10-mile trip to his local dragstrip in the Cotswolds and then only in the daytime as the bike lacks headlights. The frame, constructed from massive, 3cm thick steel tubing, is extra long to prevent the bike flipping over under hard acceleration and as it tips the scales at 1,000lb, a reverse gear is needed for manoeuvring.
With such a surfeit of power, just two forward gears are needed in the API racing transmission. Stopping power provided by racing brakes gripped by six-piston callipers.
didnt know where this was appropriate, mods feel free to move it if need be >_<
https://www.sau.com.au/forums/topic/155150-thats-not-a-bike/
thats the radiator not the cooler. it isn't intercooled. the supercharger runs like a drag cars. straight into the intake.
by the looks of where the handlebars are, you would almost be leaning against the back of the blower when you ride it.
I cant see the handlebars :S im sure there there but there hard to see...
also the seat sits heaps far back from the bars, stearing this would be fun...
Would not want to experience a blower Back fire...... shrapnel for breakfast. :laugh:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
