Go trust frount bar i searched for agers and its the nicest bar around. Im only stuck with finding side skirts and a rear bar as i have gtr skirts and gtr pods but want a bigger and smoother skirt and rear bar. What do ppl think of the veilside skirt and rear bar as i think it would be a perfect kit
Yeah i got a Garage Saurus front bar front Japan, then 3 weeks after getting that i found that Jetspeed make the exact same one lol
Depends what appeals, i hate the big open mouth front bars (i don't need ppl to know i have an big branded intercooler), loved the 400r the minute i seen it. Still looks tough when i pull up in front of a shop window. It's the only one that is noticeable in town, so many comments on ppl loving it. Theres a burgundy with it but you cant tell cuz its so dark. The extra lip on the series 2 bar, the ordinary person wouldn't even know the difference. If i had something like a gtr front bar i'd put my foot through it just to give it extras holes :D....
Skylines are boxy looking cars y make em curvy.
Stuff the rear bar, just get pods, r33's already look fat enough from behind (not P H fat either).
Holey front holey bonnet and holey side skirts with a gtr or drift wing looks phat.
EVL15h
bought this from mavric off the forums. perfect fit and top quality work
personally i love it but each to their own
Yeah man that looks great. Just the way i wanted it. Just thought id let you know i went through j-spec and got a s2 gtst pretty much stock with 66 000km grade 4.5 black. Putting a do luck gtr front with jun sides and rear. But your front bar does look tempting.
Edited by Pattygtst
Heres mine. What do you reckon? Trust front and rear bars, edge side skirts, drift wing and carbon fibre bonnet (painted)post-34941-1181100713_thumb.jpg
Mate that is by far one of the nicest R33's i have ever seen any shots of the rear? how much did you pay for that bonet and where did you get it from looks crazy good work
Cheers mate here's a pic of the rear. Got the bonnet for only 400 second hand and decided to paint it, in my opinion the vents stand out heaps more and it just sets the car off. Ignore the plate had a wrx before I bought the skylinepost-34941-1181125371_thumb.jpg
that looks great. very hot!
just a question though, with front bars like that, where do people put the front indicators? Is it possible to mod them into the side/corner lights on the headlight assembly?
PS i now think i want a trust front like that with final konnexion sides and rear...
Yeah mate thats exactly what I did, I turned my park lights into indicators, it was easy.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
