Hi
I have availble a few KFC discount cards which entitles the bearer to either 10% off or a free upsize.
Conditions are as follows:
One redemption per person per transaction.
Valid only at partcipating stores in VIC/ACT/NSW & NT.
Expires 31 Dec 08
Minimum purchase is $5.
Great card for people who regularly eat at KFC.
Price is $5 per card. Plus 50 cents postage for as many cards as you want.
If you want one or more. Please PM ME.
Cheers
PM's sent to all those who enquired. Sorry for the slow replies.
Anyone who i missed or who is still intersted please drop me a PM.
Subway.... hm.... I'm wondering if I should just grab one anyway to use in QLD then - see what I can do wit it :) What you think Razor... any chance of working? If you agree I might as well - its only 5 buks
Hi
Expires 31 Dec 08
Cheers
How did u manage to scab these?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
