Item: ARC oil cooler for R32 GTR
Condition: Excellent - NO BENT FINS
Reason for sale: not using it - don't want to lose the grille
Price: SOLD SOLD SOLD
Contact: Post or PM
You all know how good ARC are. This is a genuine curved oil cooler core for R32 GTR. I believe that ARC don't make these anymore. I have enquired with ARC and there is no grille that covers it, so I'm selling it. You know you want it!
https://www.sau.com.au/forums/topic/155408-arc-oil-cooler-for-r32gtr/
they don't make R32 anymore.
the core alone for another car is $650 + post here from Japan
http://www.arcinter.co.jp/arc/products/oil...ries/index.html
after a bit more than $200, thanks though
this is what it sits like btw:
if its core only ill give you 200 bucks delivered
Holy shit! please when making offers, particularly at 1/3 the asking price it's better to do so via pm. not having a go, just a tip.
and if I didn't have a trust kit already on my car I would eat this thing up. the ARC kit costs nearly $2K. so once you have the core for $500 and spend a few hundred on lines you would have a top shelf kit, for a china kit price. ARC cores are the nicest in the world. no question.
alot of parts arent made for cars anymore, so? - car parts dont appreciate in value like antiques and land...
offer stands - somneone would need to pay for lines, fittings, sandwich plate and if they want relocator kit aswell that also... and if you were to pay what you were asking for this core - someoen wouldnt go using rubber lines or anything so if you wanted to do it all nice - this is about a 1300 oil cooler kit once purchasing a brand name relocator and earls fittings lines etc
May possibly fit R33 GTR as well. Note that you will have to check that it will fit your application.
the dimensions are:
Width core - 40cms
Thickness core - 5cms
Height core - 8cms
width with tanks - 48cms
mounting pin centre to centre - 46cms (these are the two pins that drip into the reo bar to secure the bottom of the cooler. the top is bolted to the bonnet latch bar that runs vertically up the rad support panel).
EDIT - SOLD SOLD SOLD
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
