Since apexi is going belly up (again) and looks like it wont be doing much anymore.
And also since the r33 gts-t FC chips are now longer being used....
What is the best type of EMS for the R33..
I have been trying to look around for info and all i could come up with was the Wolf V500 which goes for around 2000 + controller.
Are there any other ones that can be used for the R33 that you swear by as great performance upgrades etc.
lemme hear your "IMHO" posts please
(car wont be modded too much, just better breathing and bigger fuel pump//oil pump)
https://www.sau.com.au/forums/topic/155441-ems-for-r33/
EMS would be my second pic from Haltech, for their price they still do a pretty good job. cant go wrong for an EMS Stinger supply, fitted and tuned for $1850....
P.S Its a shame to see such a reputable company go down like that. Especially a japanese company. Im glad i managed to find a decent PFC with h/c at an amazing price (Thanks Ben)
Cheers
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-2891620
Both the EMS Singer DOES NOT support sequential injection. And only has 4 injector outputs. Not made for a 6 cyl.
Recommendations:
- 2nd Hand Apexi PFC
- Haltech E11v2 (Plug & Play)
- EMS 8860 (last resort)
Cheers
kind of irrelivant becasue skylines only need 3 outputs. they fire two pistons at a time in parralell so 2 fire, 2 squirt fuel at a time
i run the stinger on my rb20 and my mate runs it on his rb25det vvti (ems supports the vvti) with no hassles at all, both wired into the factory harness supporting factory sensors and idle controllers, cant go wrong for the price you pay... map sensord so i would compare it to an apexi d jetro, but with way more added features and options such as lauch control,rotational idle, antiag, nos the list goes on.. only catch is you can basicly only pick one as the car will use 3 outputs (tacho output, fuel pump relay, aac? valve) so that leaves you with one optional output
out off the list above,I HIGHLY recomend EMS dude :) especialy if your looking for the cheap alternative
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-2891975
Yep totaly agree that EMS is excellent value for budget, however sequential injection is more important then people think. It is important for fine tuning each injector individualy. We all know that no 2 injectors flow EXACTLY the same therefore better fuel ecomomy and idle will be achieved with a sequential injection ECU.
Cheers
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-2892063
AEM EMS, by far one of the best fuel mgt options available for the RB.
It was my understanding that the AEM EMS had issues with the RB26 engine. Something about the CAS I think? If I recall correctly you have to physically cut off teeth since the EMS doesnt have the ability to process the excess number of teeth on the RB CAS? Now this may have been recently resolved as I did my research about 4months ago and decided to get the Power FC instead. Personally I love the AEM EMS, I used it in my EVO and loved it to death. However it just seemed like for the Skyline the Power FC was a better choice. Plus the fact everyone uses it, so there are many resources available to you for help.
-Sayajin
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-2896200
  • 1 month later...
Cheers
ECU Specifications
The EMS Stinger 4424 (Engine Management computer) is programmed in real time via Laptop. It controls both Fuel and Sequential Ignition
it says it does sequential ignition....
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-2995727
  • 4 weeks later...
ECU Specifications
You want full sequential from EMS you need the 8860
Easy to use like 4424 but stacks more input/outputs
I just wish they had a dash mounted display screen like haltech/motec
cheers
https://www.sau.com.au/forums/topic/155441-ems-for-r33/#findComment-3058087
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
