  • Replies 41
STD RB26
EMANAGE ULTIMATE PLUG AND PLAY WITH OPTIONAL PRESSURE SENSOR
700CC BLITZ INJECTORS
TRUST T517Z'S TURBO'S WITH 8CM HOUSINGS (BABY'S)
TRUST INTAKE AND COOLER PIPING KIT
TRUST COOLER
JJR ALLOY PIPE KIT
STD DUMPS
TRUST MILD STEEL FRONT PIPES
TRUST 80MM TITANIUM CAT-OUT EXHAUST
290.8RWKW @ 14.8PSI
328RWKW @ 18PSI
yeah they didnt arrive in time, i only like the to use these as they offer the best results with the combo.
we also stopped at 18psi as the car will only run 15psi during comp use.
Even so doing the runs @18psi with 3 people in the boot and a few differrent attempts to stop wheel spin we could not get a wheelspin free run..... damn those drifted on square tyres realistically i would expect a bit more say 15rwkw at 18psi and 10rwkw @ 15psi but it will have to wait. I really wanted to tune up to 22psi as these things really come on song up there but having a flashy dyno sheet was not worth the effort of changing tyres.... call me lazy.
PICS SOON
Edited by URAS
yeah what a dissapointing weekend at round two of DA for DCR, we had issues with the car all weekend.... somewhere in the 10yo factory GTR loom is an evil power robbing wiring gremlin.... car would not rev over 5000rpm consistantly.... bring on the next round.
i was suprised she qualified mid field with such a misbehaving car .....
What exhaust components did you customise (if any)?
I'd assume you would leave the front pipe sitting in such a way that any off-the-shelf S13 catback would fit.
None GTR front pipes and s13 cat back line up perfectly
trent hows the car going mate? was spuen the tailshaft let go on the dyno, cant believe the damage and it was so close to you aswell.. The dyno is fixed :blink: all is a.o.k down there, next time your on dyno i must see!!!
You guys heading down to winton tomorow with it?
  • 4 weeks later...
UPDATE:
Had the car a Calder for its first real shakedown and after lots of suspension fettling the car seems to be quite a weapon. looking forward to having some fun at wakefield on the weekend.
Edited by URAS
BTW nice looking car looks mint on the track.
I notice the power figures you quote are quite nice but @ calder it seemed to bog down a lot, fuel up and struggle to go anywhere. I know a lot of GT-R guys ditched the trust turbo's due to lag are you guys have some issues or just not finished tuning?
not sure what you mean? she could not find enough grip she was harldy ever giving it much stick ie hardly reved it over 6000 as it spun str8 to redline.... it is actually too responsive (better than the garret 2860-5's used on previous cars). and could not get traction..... maybe it looked that way as we were not drifting the last corner properly as the car holds too much speed to pull up in time for the barriers, the final corner is a no brainer and wastes tyres for no reason......
we also dont go to these practice nights at calder to go flat out comp style, we go there just to set up the car a lot of people mistake testing different aspects of the car to us actaully having problems, we had only a few handling issues (lack of traction) which is now sorted.
The car is going to NSW for a comp this weekend and we could not afford to damage so we only did what we needed not what people probaly wanted to see..... which opens a whole other issue, i dont think people should have to pay to watch a practice session because many expect to go and see drifting only. Often we will only do one section at a time make a few changes and try another section purely to save the car and tyres..... and the crowd doesnt understand this (obvious from your statement) other drivers even put in complaints that we were doing fishies on the str8 and when they themselves did it they got kicked off...... we were warming tyres....big differrence.
Edited by URAS
  • 3 weeks later...
hey trent will you and cat be at winton on the 23rd? if so, hope to see you guys there :D
The r33 is finished and is at creatd to get tuned, hopefully it goes well also being my first time on track ;)
cheers. Phill
  • 4 weeks later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
