Cruise To The Spit This Sunday 11/2
  • Replies 76
Posted Images
Damn, oh well..I'm still up for a coast cruise if anyone else is That other cruise sounds tempting but too early for me on a sunday ..need my sleep ins
I'm still in - How about leaving the meet-up details as they are and we make it up as we go along :P
I'm still in - How about leaving the meet-up details as they are and we make it up as we go along :huh:
Yep good idea!
PPLS! Its still on, and meeting place is still the same...we'll figure out somewhere to go :laugh:
should be there providing i can find a lift :huh:
ill be taking pics
Yeah no worries the more the merrier...we're not expecting a huge turn out just a couple of us that want to get together and take some nice piccies :laugh:
Hey Guys,
Here is the link to the photos, i chucked them all in my online album so you can skip thru to the end pages which has the skylines from this arvo in it.
They may still be uploading theres like 113 photos total of which probably 30 are skylines.
http://lanky71.myphotoalbum.com - Simply click the album which has "My Trip To QLD" title.
Thanks for those who came out was great to meet you all!
Drew.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
