For sale: 1993 R32 GTSt
Asking Price: $14500
Killometer's: 188k - genuine kms
Manual or Automatic transmission: Manual 5 speed
Engine Type: RB20DET
Modifications: see below
Complianced: Yes
Road Worth Certificate: N/A
Registration: Yes
Crash History: No Accident History - Inspection Welcome
Other Comment's about the vehicle:
I have owned this car since 2001, I am the first owner in Australia.
Modifications include -
PowerFC with boost controller,
GTR Injectors
HKS 2510 turbo
FMIC, Bosch 044 fuel pump,
Complete 3.5" dump and straight through exhaust, rear RSR can
Oil cooler with remote mount
ATS 1.5way LSD,
R33 GTST Brakes, Racebrakes Comp 5 and Comp 2 pads slotted front rotors
Buddy Club P1 wheels
R33 GTR front seats
Group Buy Sydneykid Bilstein Suspension, set to about 25mm below standard height
Solid Castor rods
HICAS lock bar
Adjustable camber arms
Just installed (as I type) new timing belt, water pump and bearings
Performance wise this is a realy nicely balanced R32, best dyno of 208rwkw.
Gunmetal Grey, will get some pics up shortly
No rush to sell, just not needed anymore
PM me with intrest, will consider trade + cash for a everyday smaller car ie Hyundai Getz or similar
Chris
Edited by Chris32
https://www.sau.com.au/forums/topic/155594-200rwkw-r32-gtst-sa/
  • 3 months later...
  • 1 month later...
Thanks for the bumps guys! I have a member off SAU currently interested, if that falls through then I will advertise it properly.
In all honesty, I have been in no rush and would love to see it go to someone on here with a genuine interest in Skylines, rather than see it on the news after being crashed!
Been ages since I even checked this thread,
Joel, still have datalogit, Greg sold his car so no doubt we'll offer this at some stage
Roy - yeah, unfortunatley I just don't need the car at the moment, and its costing me a fortune to keep it insured and rego'd to drive it a few time a month!
Hows both of your cars coming along? Have you been to Adelaide lately Roy?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
