my local shop was trying to fit my Xenons on my car and it turns out the "ballist" is stuffed.
he explains that there is 12V going to the ballist but nothing cummin out.
now this is only one of the ballists. but on futher inspection all the wires leading from the ballist to the globe were exposed.
im lead to believe the wires could be the reason why its stuffed not the ballist. can anyone recommend somone for a 2nd oppionion?
South East Suburbs if possible
https://www.sau.com.au/forums/topic/155686-local-xenon-fitter/
1) these kits are easy to install... i have absolutely ZERO knowledge of the workings of cars (a car fan yes, but mechanic i am not) and was able to get mine in (plug and play once you get good access to the headlights. I actually took my front bar off, not sure if that was completely necessary)
2) after-market kits are 95% poorly made, unless you get some decent brand like Philips, maybe GE and some korean ones are quite good. If you bought one of those $250 kits, good chance it's a crapper (and some can be quite dangerous in terms of engine bay fires)
3) in the end, the light will be shit from these after market kits in R34 Xenon assemblies. Fact of life. Replace with OEM parts or do a projector retro-fit, = $$$$$$$$$$$$$$$$$$$$$$$$
lol i no i no R34 after market Xenons are shiet but what else can i do...use halogens?? the thing is i know its easi to fit but the exisiting wires in the headunit are exposed.......so yeh....im actually thinkin of buying phillips now........
i got a Kaixen kit, korean made. Something about Phillips and Kaixen bulbs being the only type of something-a-rather, in other words, a decent quality one.
got pics of your kit? you should have 2 ballasts... one for each headlight.
ive wired everything up....but for some reason theres 12V going to the ballist but nothing cumming out of it. my conclusion and 2 other macanics have said that the ballist is screwed....but i wanted to take it to a auto tec to make sure.
2 ballist 2 globes wires....everythings in the box.
how much did u pay for ur Kaixen SS8 ?
i can't remember exactly. If you go check the threads that BATMBL has started in the for sale section, i bought the Kaixen kit off him. Maybe just search 'kaixen' but just choose the the 'for sale' forum
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
