Hello all,
I need to change my parking lights in the R33.
I unclipped the wire but it looks like to me that the unit is built in.
Do you have to take out the hole headlight or is there a trick to get these little buggers out with a couple of turns.
And please dont tell me theres been a hundred of these threads before.
If you have done this before please help.
Cheers.
https://www.sau.com.au/forums/topic/155690-changing-parkers/
hey,
guys anyone who knows.... I have similar problem with GTT. I can't remove the headlight without removing the whole front bar.. No place for me to take the bulb out due ti battery on one side and the pod on the other..
cheers
for the 33's theres hole for the parkers....need small hands, just stick it in and twist 1/4 turn. no need to take anything off. passenger side is easier so b/c theres no washer bottle and stuff blocking.
im sure 34 would be similar. they wouldnt design a car where you'd ahve to take the lights out to change a parker..lol
yep millions of threads on this before, one a week or so back in this section. the good old "use search" comment applied.
hope that helps.
hope that helps.
Yeah i thought there would be something on here about it.
Arr yes the search topic icon, you know its been staring me in the face all this time and i always wondered how to search topics.
What a twit lol.
Thanks for ur help.
Edited by subzeroR33
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
