Friday Night Mountain Run - Feb 09th, Mt Nebo, Mt Mee
HAHAHAHAHAHAHA
Classic
Yeah post up your pics please, leave the flaming to the photos.
I didnt take any pics as i didnt feel like it. Sorry.
Oh this can go into the main section also Zennon as its photos of a past event not advertising for the event it self... Ill move it for ya...
HAHAHAHAHAHAHA
Classic
u woulda been most help if you stayed at home :) :)
was anyone running any form of racing fuel? caus what me and john could smell wasnt like normal fuel!
and those flames, man they were some goood flames! :P
Who's the First car?....the 32?
Looks like it has Ian's rims on it but i dont know....i thought his num plate is in different spot...
Yeah who's is it again?
:):P
CLOSED-
These nights have quickly gone from mountain cruises, to mountain runs which are illegal and therefore not allowed.
Please use the term "Cruise" from now on, and organise anything else via PM
Any inference to mountain runs will result in the closing of the thread and a warning for the user.
The Mods have let it go up to now.
Cheers M
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
