Hi All
Im after some advice on where to go from here with my setup. My engine is bog stock and im now finished my suspension and breaking upgrades. The car handles like a dream at the moment.
I have R34 GTR turbos on there, the stock exhaust front pipe, I believe a 3" cat back however I havent actually measured it. The car is quite laggy at the moment and I typically hit 1 bar in 2nd at about 4,500 RPM.
Would a larger exhaust off the turbos reduce lag? I would assume they would, however its possible that the stock dumps are the same size as the entry and exit ports of the turbo, therefore making the exhaust larger would do very little?
Would it be worth going to something prefabs from HKS etc or would I be okay with a 3" mandrel bent system made up at any decent exhaust shop?
Also found these on ebay:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...p;rd=1&rd=1
Would they be worth getting? What sort of dump-back exhaust would I need? Would I be able to use my existing cat-back system?
Exhaust aside, I would like to see 400 odd BHP from the car. Can it be done with the stock 34 turbs? I somehow doubt it personally, so what would my best option be for turbos? I have had a look at the slide turbos and they seem like a good option, but he is out of stock. Also, how hard are the new turbos to install, I heard slide turbos require some oil lines to be drilled? Im after bolt-on options if possible.
I would also be looking at a PFC and injectors + fule pump.
My budget is 3000 dollars. Is this achieveable if I do the majority of the labour at home? Will I need a EBC and if so whats the best one to go with the PFC?
Sorry if this posts a bit rantish.
Thanks
Ian
https://www.sau.com.au/forums/topic/155816-advice/
i dont think stocker twins should be that laggy ?
check out some of the rb26 dyno sheets and see how laggy they are compared to yours. but if you want to make more power, then youll need larger turbo's + tune which is usually just going to add more lag (usually, not always).
https://www.sau.com.au/forums/topic/155816-advice/#findComment-2897176
Get a tune, exhaust and some cam gears and you'll have what your after dude.
That will bring it all on sooner, more power etc which is what you are after. You might need 12-13psi and you'll be away :D
Exhaust will make a big difference, and the tune another one.
So $1000 exhaust, $1000 PowerFC, $250 for cam gear and the rest will be eaten up by the tune/fitting and have you on 3k almost perfectly
https://www.sau.com.au/forums/topic/155816-advice/#findComment-2898066
are you aiming for 400bhp at the wheels, or at the flywheel?
My HKS GT2530's are at 1.1 bar of boost at 4400-4500 rpm (that was on the dyno in 4th), I have a Trust split dump/front pipes, and a 3.5" cat back system, and cam gears.
I'll get round to updating the RB26 dyno thread soon (gotta get my scanner working)
Edited by sav man
https://www.sau.com.au/forums/topic/155816-advice/#findComment-2898082
im currently running 0.9 BAR, tho it spikes to 1 bar sometimes. I would be aiming for 400 hp at the wheels (bhp, or break horsepower). I would assume it wouldnt be too far off 400 hp at the fly already.
Do I need that front pipe I posted about or would I be okay buying the dumps then geting a 3" mandrel bent system cooked up?
https://www.sau.com.au/forums/topic/155816-advice/#findComment-2898171
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
