  • Replies 42
Posted Images
Followed too close to the back of another car and or had a bad reaction time to braking...
For warning: I have a hunch that this topic may go nasty, so let this be a for-warning that if this topic slides towards personal attacks and or the event that this damage occured on then this thread will be closed...
Call me psychic but id prefer to pre-warn... :mellow:
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897866
ok, there was sufficiant spacing, however the line infront of me had to end up slamming his brakes on, as he said to me the car infront of him had to, and by the time i reacted (as i was checkin my mirrors) i was pretty close and was down to about 10 odd km when i impacted.
Ian, rung insurance they seem pretty kool, but due to the excess ($1900) i'm gonna see if i can do it all for cheaper and avoid having a claim against my name. Got a mate who is lookin at seeling his GTR bar so thats good, and i'll see if it's cheaper to get a new bonnet or reapir that one and go from there, and i'm gonna try and sweet talk the welders at work to see if they can weld the top of the fmic on for me
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897872
so you had left sufficient space, but it wasn't enough to stop in time?
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897876
Col, won't be any personal attacks comin from me, s**t happens may just have to open up the distance between me and everyone else a little more. Nothin against the even either, just really upset i didn't get to finish it, was really lookin foward to it for weeks in advance
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897881
Ouch, Ian, as in Ian with the r32 gtr?? thins for cheaper, no offence but isnt the repair job up to Ian.
PLease dont get mad,, its just how id take it.
once again sorry to see damage
I just put ians name there as he was the one who asked, i didn't run into ian
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897884
It was everyone else i was thinking about Mort... :mellow:
Let me state it for everyone else. He understands he was too close and that this was the fault of the accident. But it was just that an accident and he is taking care of the car that was damaged. So eveyone should be happy about it, he has taken the right attitude towards the accident and he will learn from the situation.
https://www.sau.com.au/forums/topic/155859-damage-pics/#findComment-2897894
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
