Ah Will, you know me mate, I love thy bling :happy:
Yeah, between your wheels and my engine bay we've got it all covered :laugh: It sounds reasonably tough for a 6. A bit loud though.
Thanks Brenton. I haven't forgotten about the BB PM either mate!
  • Replies 80
Posted Images
G'day Joel,
Getting pretty close now mate. It's running. We've still got a dozen or so smaller tasks to complete (mostly asthetic) and we 'may' end up having to swap the exhaust housing & wheel over if it shows in tuning that it's too large.
See attached pic, taken 2wks ago.
Ha-ha yeah mate that A/C install is a classic! But it works. Yeah good to meet you too. The wheels on your 33 look awesome!
That's the mean engine bay you have going there, very impressed looks s@#* hot
whatsisname :
Your engine bay looks rather tidy.
I will be taking my car to Shaun once its all back and running smoothly. I need to sort out the fuel econnomy ( or lack of) and a bit of more loving for my engine.
It doesnt help having shit coil packs in missing so much that the raw fuel just goes out the exhaust. 127km at 1/2 tank. This is from filling it up on sat morning and driving it maybe 4 times since then.
Thats insanly bad. I pull that out of the first 1/4 of a tank. :S
A couple of things can stuff fuel economy. O2 sensor and injectors.
I bought a new o2 sensor no change in economy (~350km's to a tank), bought injectors fuel economy perfect again.
Wow that was quick your already back for good?
Job prospects got better here? or didn't like brisbane?
Just too hard to leave the old lifestyle we know behind. Have many friends here and decided we just needed a break. Job prospects have been picking up quite considerably in adelaide also...
Its a bit weird but hey...
:laugh:
big exhaust leak - cant get past 12pound, need studs replaced. so its a turbo/manifold off job, new oem gaskets etc. will get shaun @ boostworks to do it in the next few weeks
damn; although I knew it had an exhaust leak however I didnt realize it'd affect it this much. oh well.
umm, a little fiddle with the safc (everything was 'pretty off'), set fpr correctly, 160rwkw with the boost not being able to hold and dropping to 8pound I believe. boost guage shows it going to 0.5Bar and it feels as strong as previous, perhaps better?
Booked in for the Fri 16/3 to fit the adjustable exhaust cam gear wheel, do the manifold stud work etc, new gaskets and all that, & a proper retune. Got quote, its a decent price so I'll be happy with the end result Im sure.
youve goto do what you feel is right no point going to sydney qld where ever to make 10-15k a year more if your heart isnt there and your not happy
Youd easily spend that on living expenses anyway. Adelaide is so much cheaper to live.
yeh mine has a afm prob atm, it might be cause the intake pipe is too short and causing turbulence and afm is havin a heart attack but will find out 2moro lol
Was that yours in the dyno room this afternoon? Were you in the camo gear?
I was looking at your engine bay thinking there was a lot of stuff in there. I was hoping to see the beast have a dyno run.
I was wearing the Barca football top and cap. Sorry, I should have said hello. That was my white R32 GTR that Troy was working on.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
