Aus. spec SR20det and auto's are 370cc from my info.
Yea thats really interesting, i have one friend with a aus spec r s15 and his are the purple colour ones, another friend that has a s15 aus spec r 99 model, it has maroon ones... confuses the shit outa me
but yes all jdm appart from auto came out with maroon (so i've seen so far)
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2905237
side feed with purple tops out of R33 skyline and s15 AUTO are 370cc,
with maroon tops out of S15 MANUAL 448cc and the JDM are 480cc from what I've heard
as i'm going to put these injectors in my R33 (maroon tops) before I do I will get them flow tested and then will confirm there flow at a given fuel pressure. I've read here and there and everywhere and everybody has a different opinion, so I guess we'll find out once and for all.
Tuners out there should know if they're tuning R33's with this upgrade as they're a pretty popular upgrade.
Cheers matt
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2905993
The problem with the s15 injectors, is they're old injectors.
I would get them ultrasonically cleaned, get the pintle caps changed, change all the orings, etc etc.
Sometimes, they'll flow well, othertimes, they won't.
they're not that cheap at the end of the day after you do all this.
The deutchwerks highflowed injectors seem to be much better.
PS: the s15 injectors always seem to flow about 440 cc not 480
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906702
Definitely only 6-spd manual has the bigger injectors.
Check the part number to be sure.
Nissan Part No. 16600-91f00
Side feed
Terracotta Top Colour
Oval Plug
Impedence : 11 ohm
They do usually flow lower than 480cc when tested as the s15 fuel reg runs a slightly higher rail pressure than s13/s14/r33.
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906747
The whole JDM vs Aus-spec thing is a bit of urban myth. I recall seeing it written by a contributor to HPI + Zoom Mag a couple of years back.
Did my own research and found the parts numbers from Nissan the same regardless of which market they originated from.
Manual spec S15 = terracotta top = 440cc (or more dependent on rail pressure)
Auto spec S15 = purple top = 370cc
Can't believe all you read all the time, so do your own checks if in doubt. :huh:
https://www.sau.com.au/forums/topic/156194-s15-injectors/#findComment-2906754
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
