Tuesday Night Dinner 20th February 2007
Thankyou Andy for your suggestion :iluvff:
The venue for dinner on Tuesday 20th February 2007 will be at Indian Appetite from 7pm.
The restaurant is located on the corner of Lutwyche Road and Le Geyt Street, Windsor.
Menu is posted below:
Please post up by Tuesday 20th Feb 2007 no later than 3pm (for yourself and your guests) if you want to come along.
Hope to see you there.
Cheers,
Karen
I'm In and Linh will be in as well....
:drool: I've been craving butter chicken and Naan Bread!!!
Mmmm saagwala.. hope its good.. i cook curries heaps.. see if i can tice the other half to come too..
Hey count me in.. its close to home anyway ( chermside)
1 (with a possible +1)
RSVP's so far:
Marc
Karen
Lee
Linh
Noel (you bringing Toby, Noel?)
Chris
Anna
Andy
Dale (ZOMG Dale is coming)
Dave
Shane
yeah, count Toby in. If its not him it will be his mum so there will definitely be 2 of us.
Sorry Boys and girls I cant make it, as its my mums birthday. For some reason I always think that its the 21st of Feb not the 20th, stupid me.
just bring her with u chris......nah dont do that :P
No worries :wave:
OK Chris we'll see you next time :huh:
RSVP's so far:
Marc
Karen
Lee
Linh
Noel + 1
Chris
Anna
Andy
Dale
Dave
Shane
Ben
If you want to come along, please RSVP before 3pm today please - thankyou ;)
Jsut checkin K... you have counted me down as a RSVP right.. the chris up there is not Chris aka GTs25t4door is it?
Also i got my +1 to come as well :)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
