Smakes on planes
nah...think older...from 1980...
another clue -
"You'd better tell the Captain we've got to land as soon as we can. This woman has to be gotten to a hospital."
"A hospital? What is it?"
"It's a big building with patients but that's not important right now."
  • Replies 282
another clue -
FLYING HIGH!!!
another clue -
airplane!
"Where are we?"
"corner of bum f*%k and you got a pretty mouth!"
or
"I think we'll be ok...I used to be a boy scout, Tom you were a boy scout weren't you?"
"No...but I ate a brownie once"
both from same movie :)
"Now... Vader, he's a spiritual brother, y'know, down with the force and all that good shit. Then this cracker, Skywalker, gets his hands on a light saber and the boy decides he's gonna run the f@ckin' universe; gets a whole clan of whites together. And they go and bust up Vader's hood, the Death Star. Now what the f@ck do you call that? "
Here's one for you!!!
quote:
Person 1: "Who said that? Who the f*&k said that? Who's the slimy little communist s#*t, twinkle-toed c*#ksucker down here who just signed his own death warrant? Nobody, huh? The fairy f*&king godmother said it. Out-f*&king-standing. I will PT you all until you f*&king die. I'll PT you until your a$$holes are sucking buttermilk."
Person 2: "Sir, I said it, Sir!"
Person 1: "Well, no s#*t. What do we have here, a f*&king comedian! Private, Joker! I admire your honesty. Hell, I like you, you can come over to my house and f*&k my sister!
unquote
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
