Hey Guys weird problem, i was driving round yesterday then suddenly noticed that my turbo wont spool up in first gear, if i put my foot flat down from stand still it will but if i take off normally then try and boot it my car will only get to the point where the boost is about to kick but it wont its like driving a NA car. Once i change to 2nd or any other gear tho everything works fine...... :/
Nothing has been changed on it recently
The car is a 33 with a catback exhaust and pod filter
yeah the thing is i checked all the hoses which all appear to be fine.... and like silver said is every other gear works but 1st thats why im lost on this one :D
well i know my car when it was stock it would boost in 1st but after i added all this mods like you said wont boost but if i rev it too about 3500rpm i can take off with full boost.
my car does that, rb25 also
you take off and you can feel it want to go but doesnt n soon as i go to shift you feel the power come on soon as you put clutch in.. have no idea what causes it mate, now i think bout it it happens in all gears 90% of time at night time :D
might be rat sh*t mixtures?
Edited by 2gceffy
ermmm my car runs best at night... can REALLY tell teh difference when intake temps go from 10-12 deg to 22-25 of daytime
10-12 she pulls 18-22 already gutless but better that a 6 banger n/a, 22-25+ gutless 4 pot pushing up a hill.
always boosts gets positive air pressure anywhere over 2k, full punt by 3k+ no matter which gear.
but even @ 15 deg she;s already prettty gutless, @ night with real cold temps she feels slugish these days though. no guts at all, but reckon thats me getting used t it. Could swear she pulled harder a month-2 ago.
meh
nope nope nope. What ceffie said is correct. make sure the actuator is working.
With my stock turbo, I used to hit huge boost in first. I've hit 16 psi in first when I was testing stuff.
My car when stock used to boost VERY well in first. If your car is not, then you hvae a problem
Yeah see the thing is in the morning it was working absolutely fine, then suddenly it just started happening, i think i went over some really bump railway track and then it started to happen, im not 100% sure that, that was the cause but its only thing that comes to mind that may have been a cause for anything to start randomly going on.
Ill check out th actuator tomorrow, but anyone got any idea why only first gear would cause the problem with the actuator cause that just seems a bit odd that it only happens in 1 gear??
after i added my mbc - i noticed shit take of in 1st . i have a gfb . but im looking at getting something better - because like the turbo tech , they just arent holding boost . maybe that could be your problem - im sure its mine . i also have a leak somewhere , it only starts wistling after iv put my foot down and let it to idle ... i still need to work out where the leak is ! - im also considering replacing all the stock vacume hoses .
check all your hoses - is my opinion.
No the thing is i dont have any boost controllers on its all controlled by the wastegate actuator but if i get one of those turbo tech boost controllers would that help the problem because that would be controlling the boost and not the wastegate actuator is that correct?
Yeah i did check the hoses it was the first thing i did but as you said i might even try replacing all the hoses see if that helps also
Thanks for the help guys
Edited by /2on
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
