Explain???
Whats this about???
You have my intrest on two topics here;
1. Sarah Michelle Gellar (on my top 5 list)
2. Nova (My favourite radio station in the morning)
Yeah, it took my little brain 10 minutes to work it out but you need iTunes:
Download Here: http://www.apple.com/itunes/
Then run iTunes and click on Advanced then Subscribe and copy paste the yellow podcast url from nova.com.au Breakfast show into the little window that pops up. then get out of your chair, spin around 3 times, click your heels and rub your nose whilst saying walla walla bing bang. And your done. :blush:
It was the first one on the top of the list as of today i spose.
Hmmm strange thoughts going through head :S What people may do with those g-strings
OMG Lets not go there
Please tell the story for those too lazy to get podcast thingo working
Cheers :blush:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
