Here you go.
Titanium exhaust side angled.
The problem with angled exhaust is if its too close to the rear bar like mine it will actually burn it. I had to have the whole bar resprayed and fixed the problem by putting in a sheet of aluminium inside the tip to extend it a bit, it acts like a heat shield. You can just see it in the pic
https://www.sau.com.au/forums/topic/157483-pics-of-cannons/#findComment-2926277
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
