  • Replies 55
what about twin hks 3037s. How bad would the lag be on a HKS Step 3 2.8l.
Dude... i give you a tip... just slow down and take your hands off the keyboard and read :)
The last few days you've started some threads with ideas that are getting more and more far fetched as you go. Each thread attracting another 10-15k ontop of the first one which makes you seem as if your a 16yr old kid with "high hopes"
1) 500awhp RB26
2) A 350Z with an RB26 & 4WD running gear
3) 2.8ltr strokers and V-Cams in an all-out setup with 3037's
Just slow down, and do some of your own reasearch please. There is oodles of info here.
Asking blind questions without even an idea of what your asking one after another after another is not going to achieve anything and is a sure-fire way to having your threads locked by me or someone else.
Its great to have ideas, more the better, however there is enough information in the world and especially on this forum.
Please take heed of the advice.
Set a budget first and go from there
Cheers.
also, if you really do have this kind of coin to throw at a car, why not think about the OS Giken rb30?
You do realise the smaller capacity RB26s are king of the dyno charts in Japan? Also, 8000RPM isn't as fun as 11000 :)
who really wants to be a mega-gay dyno queen? come on dude, ur seriously not as soft as that :)
and the os rb30's have no drama's revving to 9000rpm
I understand what everyones saying. I did start a couple of threads. The 350z with the rb26dett awd is a dream car and i was jsut trying to see what everyone says. If that plan doesnt go through which it most likely isnt i will defintley be swapping a rb26dett into my 240sx. However im not going to go that crazy on the motor then. If i did the 350z swap then i would get the hks step 3 2.8l and the V-Cam. I do have the loot. I have about 20k to spend.
furhter more to that post above, i dug up an old dyno graph i have.
it had better be 20K english pounds...
lol Shane :)
Shabib - your going to need a LOT more than 20k make.
The stroker kit alone is almost half of that before you even put it together an purchase any other parts at all which comes to probably another 15k
lol i dont necessarily have to get the hks step 3 2.8l. Thats why ive been asking about the tomei 2.8l stroker kit and how much hp it can hold and how high it can rev. Its about 2k cheaper than then the hks kit.
well I'm assuming you are in the states, but even 20K USD is a long way off building the type of car you are talking about. it's not just a matter of buying a 2.8kit, a T04Z and a V-cam and then ships ahoy matey. you will need all new pulleys, harmonic balancer, prepped N1 block, complete re-done head (try buying 24 titanium valves, double valve sprins, retainers, cams, guides and then having it put together) if you want big HP and big RPM, and you want it to last more than a few passes you will need the BEST of everything. add to that a quad plate clutch, a dog gear set (or would sir prefer hollinger sequential at $22K AUD?), then add your new intercooler (cost $2.5K AUD alone), new radiator, twin oil coolers, diff cooler, trans cooler, bearings, gaskets, engine assembley, ignition system, ecu (i'd suggest motec for this set-up), injectors, fuel system (twin pumps, surge tank, all new lines both return and feed, twin feed rail, fuel reg etc). let's do the oil control. you'll need custom dry sump set-up with at least a 4 stage pump, boot mounted tank (with warmer) and all plumbed up properly. then full custom exhaust and intake piping, since we have come this far let's make it titanium as well. now you will need some nice wheels to go with your $80K set-up and some tyres to go on them. and don't forget the rest of your car is still standard and looking like crap. so lets throw in $10K on body work (conservative), and around $5K on suspension. then leave $6K for brakes so you can actually stop. now you are going to run your 900hp GTR (or whatever car it is today) at 12,000rpm on the street, so you had better be prepared for regular check-ups and inspections. may as well lease a workshop for a year, and hire your own private mechanic as there will be a years work to do building your car for one man no problem.
$20K USD will buy you fck all on that list.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
