Hi all,
I will be upgrading my turbo shortly and would like some info on removing the stock one.
a) Do i need a hoist?
b) Can i get at everything under the car?
c) Do i need to remove pod,AFM,intake hose to turbo?
d) What lines to the turbo need removing?
e) Its going to matched with a VG30 rear housing do i need to keep all the fittings?
f) How long will it take roughly?
g) Will any oil or water leak out of the engine once the turbo is removed?
h) Is putting the upgraded one in just a reverse procedure or do i need to modify (add new lines)?
P.S If anyone wants to save me the grief.PM me and we can work something out.
CHEERS
https://www.sau.com.au/forums/topic/157667-removing-stock-r33-turbo/
Hi all,
CHEERS
1: u dont need a hoist 2: u can get everything from uinder the car 3: yes 4: 2 water lines and oil lines (feed and drain) 5: pretty sure u can with the hiflow 6: about 5 hours 7: water will piss out lol 8 : if u hiflow probably not but its good to drill the oil feed line with a 5 mill drill bit (remember hiflow only)
good luck mate lemme know how u go
Edited by R33GOD
a) Do i need a hoist? NO
b) Can i get at everything under the car? YES
c) Do i need to remove pod,AFM,intake hose to turbo? YES
d) What lines to the turbo need removing? (Water lines in and out on each side of turbo, Oil feed and oil drain)
e) Its going to matched with a VG30 rear housing do i need to keep all the fittings? (Yes keep all fittings and get new gaskets from nissan)
f) How long will it take roughly? (A LONG TIME, it took me ages because i had to keep buying tools/gaskets/bolts, BE careful when undoing tight bolts spray with WD40 first and wait then attempt so you don't snap anything, a breaker bar is also handy)
g) Will any oil or water leak out of the engine once the turbo is removed? (Best to drain all the coolant out first as when you disconnect the water lines coolant goes everywhere i was swimming in it lol, same with engine oil)
h) Is putting the upgraded one in just a reverse procedure or do i need to modify (add new lines)? (Depends on which highflow you get, GCG straight on SLIDE needs mods to lines)
This site will be useful for you (still a Rb25det)
http://www.project32.net/tutorials.php
http://www.livesockets.com/quoc/rb/10_mani...moval/index.htm (was working when i did mine but not now ) :( maybe check through livesockets.com
http://www.livesockets.com/quoc/rb/10_mani...moval/index.htm (was working when i did mine but not now ) :laugh: maybe check through livesockets.com
loool it happened to me when i took the water lines off... i got soaked but it was soo funny :(
http://www.skylinesaustralia.com/forums/in...157088&st=0
this is a thread on some poor nutter tring to do similar on a GTR. they are much harder. but take a leaf out of his book!
be prepared for the worst! the GTS-t turbo is not that bad to work on. I have a small plastic tool box full of old turbo bolts and brakets and fittings. They come in very handy right when you think you don't need them. my advise is to keep every last bit of it. U may not like the new set up, and want to return it to where u started. u may loose something or worse, break it! keep the extra stuff!
I took all the intake hoses and stuff out of the way, the cross over pipe and BOV. rolled the car out of the shed and drained the coolant from the radiator (there is an screw in the bottom). pushed the car back inside and and removed the dump pipe. unbolted turbo and carefully pulled the turbo off. make sure u don't lose the brass washers off the banjo bolts on the turbo. swap the parts u want to swap, and do the hole process backwards..
Before unbolting the turbine housing, use a yellow paint marker and dot the housing position. it will help u when u are putting it all back together.
ohh, be very careful when tightening up the turbine housing to cartridge. make sure that the wheels can turn freely. i've seen guys do these up cock eyed, and the turbo doesn't spin!
any other thoughts :(
I'll add, you need a 24mm spanner and socket for the water lines.
Oil banjos is 17mm spanner/socket.
Drain absolutely as muhc of the water as you can. I got 4.5L out of the radiator, and another 5L came out of the turbo water line.
Try and undo the bolt slowly, and catch most of the water, otherwise you'll be lying in a pool of coolant. While it does taste nice, I don't advice drinking it.
Jesus tap dancing christ!
This is going to be a BIG involved task.
I dont think i will be able to have my car off the road for that amout of time.
I work 5 12hr shifts and need the car on the road.I guess i have to do some serious organising to limit the time spent.
Not to mention the turbo place needing the turbo for a day or 3.
Thank you all for your excellent advise.
honstly, if it's your only car, I wouldn't do it myself. The thing is, with these performance cars, if you like to mod them, it's guaranteed that you'll need to hae it off the road.
e.g. you might break bolts, or break something, and it'll take you time to go buy stuff etc.
My car's been off the road for 6 weeks waiting for different stuff.
I wouldn't advise you to do it all in a day either. I'd spend one day taking it out then the next putting it back in.
Also, how mechanically able are you? Do you get pissed off easily? do you have the right tools?
If you want, i can tell you a plcae that'll do it for about $350 including coolant and oil
Im listening.
your very welcome mate
hey mate what plans do u have for your 33?
I am about to do thesame with my car, dam gaskets and studs.
Overall if you ahve two people, the job is EASY. just takes time and patiance. The Nissan manual has a good DIY on how everything has to be performent and in what order.
I can send a coppy of relavant pages, just PM me.
Overall cost i sabout $200 for all the gasktes and so forth allong with some new studs. Possible extra for coolant.
If you start at 8 in the morning, you should have it done by the afternnon no probs.
UNLESS, you break some studs, and can't get them out, need some helicoils, or have a warped manifold.
I comed propered and have broght everyhting possible to ensure i can do it in one day, as i too need my car on the road ASAP.
if you're going for 280 rwkw, a highflow won't do it. in which case, it'll need to be something else.
If it's a kit, you're alright. if it's not a kit, you'll need fab work, so you can't do it yoursledf
ive seen these VG highflows pull 280rwkw at 19psi.Car had tomei cams and all supporting mods.
280 rwk is pushing it for reliability on a hiflow id say 260 is possible with reliability.. im chasing a comfy 240 on a lower psi
Edited by R33GOD
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
