Hey peeps, looking at selling my R32 GTS details as follows:
90 Model Import
Delivered Sept 2005
RB20
Manual
Sedan
Metallic Silver
Rego till Oct 2007
GTS-900 plates
80XXX Kms
Std MSpec version
Sunroof
Remote Alarm
Xforce exhaust
Pod filter
Profesionally lowered
Momo Gearnob
Above are the only modifications, and i have all equipment to take the car back to standard.
Body is 100% perfect, not a dent or scratch.
Driveline is great.
Tyres are 95% new.
Interior is 98% perfect, 2 little burn marks.
Link to carsales add http://www.carsales.com.au/used-cars/priva...20South%20Wales
Not a cent to spend.
Now $12500
One of the better GTSTs going around.
Can email pics as i do not know how to put them up (sorry)
Located near Chatswood (Sydney)
Regards
Ari
Edited by GTS900
https://www.sau.com.au/forums/topic/157715-fs-r32-gtst/
  • 3 weeks later...
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
