Hi Guy's
Now i just spoke to my tuner and he's very reputable and knows his stuff he said that there's no point putting cam gears on standard cam's on the 26 as there is really no gain.
the car i have is an rb26 with R34N1 turbos C106/GT25 A/R 0.60/0.64. full boost at close to 5 grand at 1 bar will these cam gears actually bring that down or not????
i want people who have done it to there car's with the standard cam's to let me know there results.
very very confused because i hear people saying that you get good gains and stuff but now my tuner saying it really doesn't do anything has crushed me.
Cheers
anthony
https://www.sau.com.au/forums/topic/158108-rb26-and-cam-gears/
Hi Guy's
If thats the advice being handed out and especially with R34 N1's on there...
Time to change tuner IMO.
There are a number of threads with before/after/comparo etc to backup the cam gear gives a much meatier mid-range if installed/setup correctly
Hi r31 nismoid
i tried to search for rb26 cam gears on the search function and really didn't get anything can you point me in the right direction on what it is i should type in to get the right results for the question that i'm asking.
Cheers
anthony
yep, stock cams.
change tuners though dude, seriously.
If they cant get/dont think cam gears give a gain... then its not a good idea to give them a set and tell them to "make the car better" as they obviously wont be able to given the advice.
similar results with the cars we have done with standard cams and turboes etc. Worth doing in my opinion. Even better results with a set on poncams though.
Perhaps time to maybe re-educate your tuner :(
Mike
yea it looks like it's time to reducate him but i don't understand cause this guy is great he alway's tunes my car and know's bout them inside out. i've heared they give gains but after he said they don't i was sort of aprehensive about it. but i'll give them a try i had an rb20 with a gt30 on it so i want better responce than that and with the gtr making full boost at 5000rpm i want it to come down.
these are with N1's with .6 and .64 rears what do you think it'll come down to with the cam gears. what i mean is when do you think i will see full boost???
and do you think it's worth doing the dumps on the turbo's i've heared they really don't make that much of a difference ?? up to 320rwkw on the gtr's
Cheers
anthony
  • 4 weeks later...
how much boost is full boost?
i think with the .60 front .64 rear combo N1s you should be able to get to 1 bar before 4500rpm with some smart tuning, some dump pips and some cam gears on stock cams.
Well at the moment full boost is 1 bar but after i change injectors and cam gears full boost will be around 1.3 bar. so any ideas when i'll be seeing full boost?? also
since these are the larger (.6 front and .64 rear) N1 turbos what will be the max power i can get with them??? before it becomes inefficient
Cheers
anthony
Hi, with poncams, dumps and -5 garretts, similar specs to N1's, I reach full boost (17PSI) AT 4000RPM.
Before cam adjustment it was 4300rpm. They were already pretty close from the old engine and that was moving the intake only 2 degrees.
That 300rpm on the road, though, translates into hugely improved spool up when over 3000rpm. Very worthwhile addition to the driving experience :(
Mike
If you have never tried a different tunner how would you know his great??
Seriously if his under the impression cam gears are a waste on a 26 his not worth the coin your paying him!!
Ive got plenty of grphs just like beer barons that can show the same gains, both 25's and 26's.
And Id agree with some nice tunning work there is no reason why 1 bar cant be made by 4 grand.
  • 9 months later...
Will it be ok to leave the adjustable cam gears set to 0 on my rb26 until i get a chance to get it on the dyno when i get the power fc installed?
Can they just be put straight on and driven for say a week set on 0?
one line is before cam gears. one line is after. nothing else was touched. now make up your own mind it it's worthwhile or not. :/
Do you know what the final change of the gears were ? for inlet and exuast?
+2 to +4 intake and -4 to -6 exhaust is the normal range for stock cams adjustment gains.
The improvements have a larger magnitude on larger turbos.
There is also throttle response improvements under load, these are certainly felt but, often not mentioned.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
