Depends what it involves man.
E.g. whether he can just use an easy out with everything still in the car, or whether all th eintake piping has to come off, turbo off, manifold off too.
Why do you care if a stud is broken? Is it leaking exhaust gas?
Yeah its leaking.Performance has dropped big time.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938376
1000 is a bit steep. look at it this way
mechanic has approx 4-6 hours work putting on/off all components to get to it. so that would be probably $300 mark
than a thread repair guy will come to extract broken stud, $50 to $500 depending how many/what damage has been done/time spent blah blah
that materials will cost you about $200 ($120 for exhaust gasket, $45 for turbo one, $2 each stud and $2 each locknut all from nissan)
so really shouldnt be no more than $800 at most considering you dont need to pay thread repair guy $500
mine all up was $700 including parts, labour etc.. thread repair guy said he has never seen anything so bad in his life ($350 he charged) so im guessing yours aint that bad
people have done it themselves and it only cost them the gaskets plus some ezy-outs so depends really...
Edited by tek_01
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938388
Where did u get your's done at.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938417
How confident are you in doing it yourself, thats what i did the only thing that cost me was gaskets 1 stud and to pay threadtek to come and get it out (90) and plus you can get the exhaust gasket cheaper than that and not in nissan oh and studs well $1 each and $1 for locknut, over took him 10 mins tops to get it out, the first stud is cheap, but sometimes you may brake more than one when you remove the manifold. .
$1000 is still dear as. all in all took 3 hours tops to remove and fit manifold including time of threadtek.
fun and games tho good luck
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938462
I'm gonna give it a go.Shouldnt be to hard.Where did you get your parts from?
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938485
What mechanical experience do you have?
What is the biggest thing you've done on the car? have you ever done the turbo before?
Do you have car stands? Decent trolley jack?
Good socket set and spanners? breaker bar?
24mm socket? 24mm spanner?
Once you take the turbo off, you'll need new coolant too (about $50).
Got a lock up garage?
Is it your only car? can you affor dto have the car off the road for 2 weeks?
Do you have time, or can you only work on it on the weekends?
Keep in mind part shops mostly open weekdays only.
Not doubting you in anyway, but just tryin gto make sure you understand what you're getting yourself into.
Things always take longer than you expect
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938532
I know its not gonna be a easy job.I try to do everything to myself.Work,Nissan and Auto 1 is just around the corner is a big bonus.Got all the right tools so i'm gona start on it this weekend.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938578
Its always fun to do it yourself, I only broke one stud lucky in my case but 4 others just came out of there sockets so i still replaced them, usually the ones that brake are either ends of the manifold 3 near cyl 1 and 3 near cyl 6 WD40 always helps, and where are you located?? Also it shouldnt hurt much if you drive it around with just the one broken, just poor power and no boost if its leaking.
Also ring up your mobile thread tech that are able to drive to your house and remove it for you for a quote on "x" number of studs, Unless you have access to a right angle drill, air compressor and easy outs as these things come in handy when doing something like removing studs, Or 12v drill, stud tap, and easy outs will also do the job, but there isn't too much room either end of the manifold. You will guage what i mean when you do it yourself.
Oh dont forget to clean those metal filings away either they can be nasty. And get the tools and bits n pieces before you start it makes it alot easier as well.
The gasket, you can locate an aftermarket one for less than 100 give repco a call they may help you here.
You get many things from doing these yourself, Experience and knowledge of repair giving a sense of self achievement and also money saving.
Cheers
A
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2938984
Cheers
A
I'm from (Sydney) blacktown.Yeah i like the feeling that you get when you've done something to your own car.You learn from your own mistakes right.Thanx for your replys bro.Same go's to everyone else who replyed.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2939082
all i say is have someone handy (like a thread repair guy who can come over) to pull the studs out if you cant, that will probably be your biggest problem but apart from that should be okay if u have the tools and not too bad with your hands
and to answer your question above, i got my mobile mechanic to do the work and another mobile guy came for the threads
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2939851
I got "Action thread repairs" to come and get my broken studs out - there were 3 broken and 1 more broke getting it out. He charged less than $100 including all new studs --> AND he is also mobile so came to the workshop where i had my car stored. Just required that dump pipe and turbo was removed so he could get in there.
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941285
Yea 1k is very expensive for exhaust manifold stud removal... the studs are like $4-$6 each... but the labour involved is what is going to hurt... but 1k... f**k you'd want them to rip out your motor and do it on the bench for that much lol...
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941306
They were charging $98 an hour for labour.Being a well known workshop in sydney i know i'm not going back there again!
https://www.sau.com.au/forums/topic/158279-zorst-manifold/#findComment-2941393
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
