Old topic I know...but since my cooling system if filthy as hell I decided to replace some of the old gear for:
New radiator silcone hoses
ASI 42mm aluminium radiator
Low temp thermostat (62C)
also keeping the stock clutch fan for now,
is this a good improvement for my car?
why the low temp thermostat? unless its getting hot there should be no need for it, it can actually be worse as cars are made to run properly at a certain temp and if it dosnt reach that temp they wont run to there full potential.
well it should lower operating temp of the car which should make it more efficient and as skylines tend to run very hot it should be an advantage?
operating temp might be lowered be around 5-10C and i dont see how that could harm the car?
mine runs at 75-85 thats far from hot and from what i have read most people run around that temp so if yours is getting hot (which i would class as a constant 90+) then you have other problesm you need to fix instead of masking the problem with a colder thermostat.
and running cooler wont "harm" the car its the fact that the fuel and ignition maps are altered depending on engine temp so if it isnt in the range that the ecu likes then it wont be running at its best.
Edited by W0rp3D
  • 1 month later...
here u go as promisted
its a tridon brand part no TFS141
its used in most mitiubishis model from 1992-2004 (ie lancer ,3000gt,manga,mirage)
and it even comes with a o ring
herea a pic up against the factory 1 (yes the tridon 1 is the nice shiney 1)
with this temp switch, how do you wire it up with a relay?
  • 2 months later...
i put this on the other week and it worked fine for 2 weeks and has stopped working. has anyone else had this issue?
i had it wired up as an earth switch, is this the way its meant to be done?
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
