  • Replies 50
i drove my mate's 1995 model 180sx the other day with blactop sr20 which is the same engine used in the s14s aswell. it had catback exhaust and pod. honestly, straight line speed wise it felt alot like my parents' VT 3.8 v6. definately not as quick as i thought it would be.....i haven't driven a r32 so can't say which would be quicker...
factory times say both do around 15secs for 1/4 but keep in mind the r32 is a few years older than the s14s. personaly the series2 s14 has one of my favourite front ends, very mean lookin. but the rest of the car is average. and i hate sr20s.
RB20 engine/exhaust note has to be one of the sweetest sounding ever
Edited by R-SPEC
A common misconception is that the blacktop SR20s are all the same. You can basically say that the S13/180SX motors are the same with different cam cover colours.
The S14 (and S15 motors) are different to the S13/180SX motors. Among other things, the S14/S15 motors have -
-Variable Inlet Camshaft Timing (NVCS)
-Larger turbocharger (T28 vs T25G)
-Different inlet manifold setup. (Low port vs High Port)
S15 motors are slightly different again but is of little overall significance.
Cheers :(
stupid question.. this is the type of question that should come from boostcrusing..
sigh.. well basically the S14 is superior, lighter more usable.
180sx S13 red and black are near the same. the S14 and S15 use 28 turbos and have VCT. and high port inlet.
not all s14's have variable cam timing. only the late series 2. you can tell by the lump on the rocker cover.
All S14s have variable cam timing as well as the points i mentioned earlier. How do I know? Because I own both. :(:huh:
but stock they are both slow the s14 and the r32
My r32 when i bought it was stock except for a 3" exhaust but only from the cat back... This exhaust was one of the worst I have ever seen, terrible drone and if anything was causing a loss in power, when i changed it down the track I noticed the difference straight away!
Anyway, with that sh!tter of an exhaust I g'teched my car and ran 0-100km/h in 6.5 seconds. I personally dont consider that slow... but its all in perspective i guess.
but its not fast
Regardless.... YEARS ago back before SAU was born (2001/2002) I was on SDU. One bloke managed a best of 14.2 1/4 mile out of a dead stock R32 with a good launch and some wide tyres. So not really stock as it wasn't running its stock 205/55/16's :unsure:
lmao... @ 11ty billion.
