upgrading to ppg box due because seeking new higher power levels and dont wanna risk breaking this
box is approx 10k old, i dont have the receipt as i got it off a friend, but it has been inspected by smithfield diff and gears and they said its fine and confirm the gearset.
gearbox was behind a 300AWKW r32. push? type i believe, the 1 r33 is not :D
lookin 4 $3500.
freight by buyers arrangement and expense.
** can get pics but u all kno wat a gearbox looks like lol
Edited by 747.GTR
  • 4 weeks later...
$3500...wtf this is a give away...look at the costs...
GTR 2nd hand box...$1000
R33 update parts (requred for OS gearset)...$700
labour for overhaul and installation...$700
5 speed OS gearset with upgraded input shaft (if you can get one)...$4200
grand total $6600
BARGAIN AT $3500
Its sold. I know because I tried to buy it off him. I don't know what his problem is but he is a pain in the butt to deal with. He also uses a couple of usernames.
Edited by dontfeelcold
yeah i pmed this chap about 30min after he advertised the gearset and never heard from him......
i say its sold or he is not sure what to do :)
sorry its sold.
