paul, you toucha my car, i puta my foot in yo ass! lol, i may look like a teddy bear but don't make me loose it.
and yeah smoky is definately a soft target, i say go for it.
  • Replies 665
ive met smokey he is ok
the rest of you lot.....
Right back at ya Paul :ninja:
Sif Smoky is ok.. He is the biggest trouble maker out of them all! That's why I constantly have to beat him up..
Violence against men.. Australia says no!! :P
Bring it on SAU VIC!! :)
This coming from a guy who has ice-cream mixed in with his coffee :ninja:
Bring it on Teddy :)
:O Dont beat up Smoky... :)
lol, i'm just kidding. do what you will....
seriously though, don't do it. i'll f**k you up.
LOL I have never seen Baron get all tough *gets popcorn ready* that would be cool :)
You dont see me complaining!!
Know your place woman!!.. get back to the kitchen!!
:P you get that just for saying that crap :ninja:
This coming from a guy who has ice-cream mixed in with his coffee :laugh:
Bring it on Teddy :D
LOL I like how all this stuff is coming out of the wood work ....dont really know peeps till you go on holiday with them :laughing-smiley-014: :laughing-smiley-014:
This is going to be GOLD!!! :D
Are you sure it was ice cream Richard had in his coffee Al?? :huh: It could have been "self serve"!! :laugh:
:O Dont beat up Smoky... :P
;) you get that just for saying that crap :rolleyes:
Thanks Jess :happy:
Hahahaha!! I speak the truth!! :P
This coming from a guy who has ice-cream mixed in with his coffee :thanks:
lol, it is called an affogato after all. but you fail to mention that ice cream and coffee came with a shot and I was the only one man enough to get any drinks in. everyone else just hurled excuses out there. :D
we in vic dont drink
i know tell me about it. at the GP everyone was kind enough to let me snake beers from their eskies. if I tried that shit in nsw I would get a 2X4 over the back of my head right as I reached for a cold one.
Man - not looking forward to the long, boring drive down :(
Corinne - bring some good movies on the ipod :(
Haha... Im sorry but there is no porn on it Chris...
Not to mention your not allowed to watch while driving :P
I hope you will like my singing in the car.. yes im a singer! haha
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
