Hey all,
Just a quick post. (im at work)
I have a RMR30 white Ti Hatch, power windows, mirrors, air con, intirior is smokey and stained,
engine has 390xxx km ( 3 injectors working too)
power steering
new windscreen
sh1tloads of good stuff....
I am planning to keep he following (to get my good Ti on the road)
Tyres
Exhaust
Some steering components
Manifolds
5speed gearbox and associated parts
front bar, radiator and fans
Ti rims
SO IF YOU WANT ANYTHING GUYS LET ME KNOW!!!!
It cant stay in my driveway forever, so if you want anything you can have it name your price (nothin stupid like $10 for the windscreen)
PM me here, or sms on <removed by mods>
postage/freight will be from Ringwood Victoria (S.E. Suburbs of Melb)
Im not looking at making any money, just the hole in my pocket need to be reduced!
PICS to follow soon
https://www.sau.com.au/forums/topic/159138-wrecking-rmr30-ti-hatch/
I cant believe no one wants anything!!! 15 views and no replys!
the front end is sold, will be at bodyworks in Bayswater as of monday next week, so get ya goodies now!
wheels are sold too
heres the only good pic i have
Ok if you want to offer budget prices im ok with that....
Even if you want the rest of it for $100, i just bought it for the parts i needed...
Wreckers are prowling for these too...
wheels are sold too
what do you want for the ECU ?
I looking for a spare.
is there a difference between an Auto or a manual ecu??
i am going to swap out my auto adn replace with the 5 speed manual later on in the year
just not sure if i need to use the manual ECU yet...
If i dont need it i guess you can have it for $15 + postage
took it out for a spin last night, man i love the manual!!!
even with 380,000km on it the L24e still performs!!! (blasted a vt commodore, was close though...)
i stripped a few interior parts (seats, spars wheel), and switches etc.
a few bits are spoken for, still to be confirmed
pics attached
pics attached
ANy chance of a rear demist switch?
Hi again...
The white wreck is needing to be permanantly removed pretty soon, so are there any last takers on parts??
theres alot been stripped so far, but let me know if theres anything you are interested in...
Its off to the wreckers soon....
for sure! $50 is what i was thinking of, but wasnt sure if it was too much or not...
you can email me on
<removed by mods>
I go to Brissy tomorrow, and will be back monday night.
The car is at a bodyshop in bayswater, and it will be getting towed back to my place after easter sometime.
(or i will strip it there and get it towd to wreckers from panelshop)
  • 3 weeks later...
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
