Ive recently had trouble with PAR boxes in a customers R33 GTR. Its making 420Kw and is having huge problems with 3rd.
Looking at the gear they start as a 2 peice gear, the actual gear itself then the syncro dog teeth are on a separate ring thats welded to the gear, In this particular case the welds are constantly breaking around the gear.
PAR don't want to know about the problem as you would expect.
They seem to beleive oh the box was built a few years ago and its normal for them to fail after a while.
My x misson box has been taking the same ammount of grunt for a while and Ive had no problems at all. Id expect the PAR box to be more than capable as well.
LoL, and thats JUST a fun track car! Hahaha. Thats gold hey.
Yeah, OK, so I tend to get a bit carried away with these things :( I dress like a tramp, don't have holidays, and do 99% of my own work, it's a kinda drug I guess :)
I must say I didn't realise PPG did a sequential kit. Will this fit the R33 GTS-t casing, or is it for the Getrag casing? Thanks for all your feedback SK. The stock box is slowing me down a lot. The ratios are all to pot, second is too low, I never use first save for starting off, and the change into fifth is slow, and 3 rd and 5th synchros wear out for fun. I now NEED a decent gearbox in it, a proper weld in cage to get some tortional rigidity, and some more power, which should be addressed by an all steel RB26 lump which I have nearly completed. Once the cage is in I'll be a lot happier to fit some nice carbon doors i got vac moulded here in the UK at 2.8 kilos each, with full stock pattern internal shells. I feel too vulnerable without the stock steel doors with impact bars and no cage, particularly after stuffing it sideways into the barriers at Oulton Park last year...
We use Hollinger sequentials in the Hollinger case with the standard transfer case (4wd) or without (2wd) wherever the regs allow, I have never seen a PPG sequential.
You need an RB30, the standard gearbox ratios are fine with their power spread.
At the worst (2nd to 3rd & 4th to 5th) we logged around 2/10ths of second faster up shift with the dog box over the synchro box. At 30 odd gear changes per lap, it adds up to around 1/2 second per lap faster using the dog box, or the length of the straight in a 20 minute race.
We have to use standard panels, no lightweight stuff allowed.
A nice cage certainly makes you feel safer, plus it adds a bucket load of rigidity. We can come down ~25% in the spring rates once the cages go in.
:( cheers :)
Some pics of our synchro SR20 PPG, we opted for the billet selectors aswell as these are half the reason these boxes wont shift gears at high rpm.
Edited by URAS
In the first pic, is the shaft that is at the front of the pic one piece?
Nah it has to be removable for assy, but this is where the OSGIKEN gearsets were breaking (not sure where the PAR ones keep breaking). The OSGIKEN used the factory key way setup whereas the PPG uses a better spline setup (look under bearing you can just see it)
for the ppg gearset in a rb25 5speed. With the 26t spline uprated input shaft you need to run the std size bearing(23mm i think) and shim it up. We tried to run the bigger bearing (26mm) but it pushes the input shaft 3mm too far into the box.
Thats what we have found out that was a slight issue with the gearset in the 25 box.
Typically the PAR (pressision and robotics engineering) boxes have a 2 peice gear. The gear itself is tough however the dog teeth section is made separatly and then fusion welded to the gear. Typically the ones ive seen have broken the welds and the syncro dogs simply spin on the gear.
The only good part about the PAR gear set is that the lay shaft (lower Gears) are actually modualar and can be removed from the shaft so it saves alot of time come repair and maintanance as you dont have to strip the whole box from the sandwhich plate to access individual gears and syncros.
  • 3 years later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
