tuner rekons to make a maximum of220-230 rwk i need to raise boost to at least 15-16 psi on a the hiflowed slide turbo but is it safe at that boost level with stock internals? here are my mods incase no one knows
-hiflow slide turbo
-pod
-pfc
-fmic
-3 in turbo back exhaust
- ebc
-555 cc injectors (in the way)
-tomei fuel pump in tank ( on the way)
https://www.sau.com.au/forums/topic/159453-is-15psi-too-much-on-r33-gtst/
So basically if it took 10 psi to make 200rwk stock turbo and 10psi on a gt30r made for arguments sake 230rwkw. The eninge is under more load with the gt30r?
AM i correct saying psi is not a direct relation of stresses on teh motor.
More correctly put it would be that there are other stresses, RPM being the most dangerous.
:P cheers :O
provideing you can control the thing from pinging have done a few 25s but timeing isues always pop up but you should be ok with these mods you have .
Not so much of a problem these days with high octane fuel and ethanol eg; Shell V Power Racing 100 ron with 5% ethanol.
:P cheers :O
im fairly sure slide turbos are rated to 19psi safely... as far as what the stock internals will take.... i read that anything less than 270-280 rwkw is fine on stock internals.. so in answer, you should be able to easily run 18 psi quite safely.... with supporting mods you should be able to hit 250...
p.s. u will definately need that fuel pump and the bigger injectors to start getting much past 220-230... once you get those put in, go and get it retuned @ 18 PSI (or 20 if your prepared to accept the risks).
also remember that just because 9/10 people can run 18 or 20 psi every day with no probs, im sure there are stories of people running 16 psi on a highflow / bigger turbo that had their stock internals give up... its the risk u take i guess.
I run a Garrett GT3037 56t, .63 rear.
This thing pumps out some serious power, but is also a tiny bit laggy stopping the motor coping a hard hit everytime the power comes on.
I also cheat.........Water methanol Injection..
That cools the combustion temperatures by heaps, and prevents a lot of detonation. At one stage I did a few runs at 24psi and it just kept on pulling. Absolutely no detonation, and the AFR's were spot on.
Edited by The Mafia
unless we can see the compressor flow maps for it saying its safe for xyz psi means nothing
its just the turbine speed that is driven by the manifold pressure. the more pressure the later the wastegate is opened, which means faster compressor speed. it doesnt mean its flowing more useful air, just means there is more pressure.
well my tuner told me to run 16 psi so if he blows my car up he's payin for it lolz
you can run whatever boost you want as long as the tune is spot on...
should tune it on 16psi and run like 15 or 14 to be safe if your paranoid...
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
