  • Replies 194
If we have to be at etsa park around 11 and at the final meet point at 1, then im thinkn us guys out north should aim to meet say at Munno Para Maccas at say around 10am? What do you think dave and lee and anyone else down our way?
Yes Maccas at Munno it is. I'll be there :blink:
its so much easier if everyone meet at one specific location and not create a whole bunch of mini meet venues to all meet at a larger meet venue and then all head to the main meet venue.
for all us northerners and every other locationers.......please meet at ETSA CAR PARK AT 11am sharp........i think this is best so noone get confused
Everyone.................................
Pre Main Meet Point will be 11am at Etsa park. I will Be there from 10:30ISH. So Everyone Look for My Broom Broom.
Im having Missing problems again So No Hard driving for me.
We will then cruise on to the Main Meet Point Down South at Around 11:45ish.
Now I suggest everyone has lunch before Meeting up at ETSA Park. Or Bring it there.
It's going to be a long day so please Everyone remember to bring a Street Directory, Plenty of water.
CAMERA's, Videa Camera's.
And a SMILE. This is going to be a great day and All who Attend will be helpng out a very good Cause.
I will be printing some maps off tomoz *cough* "work" *cough*.
I am going to be printing the maps off for all the ppl in the first post by Darren.
So If you aren't in that first post make yourself known to myself or Darren and we will fix it up.
Yes I will be printing off more maps then ppl coming for others that are bound to come.
Please remember its a Gold Coin Donation. As I am aware its going to be an expensive day so anything helps really.
Looking forward to Sunday.
P.S
24 Degree's is very nice for the Turbo Charged RB's. MMMMMMMMMMMMMMMMM
hey guys, id love to come to this if anyone out north has a spare seat (lee? grim?)
ill have the video and digi camera ready and waiting aswell, so if anyone has a spare seat available... :P
hey guys, im in for this youth awareness cruise.
im from west lakes, where can i meet up beforehand? anyone mind if i come to etsa park with you boys
:P
no worries!
hey mate, your welcome to meet up at esta park, the more the merrier i say!
cheers
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
