Hi all
After some advice on which turbo/turbo's to run
Im chasing 400 awhp on a safe tune, with boost settings at 0.7 bar low and whatevers required for 400 hp on high.
I have been looking at a set of 2560R's. Whole aim is to keep the response while providing respectable power. a set of slides would also do the job however there not rated as high so I would probobly be asking more out of the turbo and im not so sure about the journal bearings? The price difference is quite large however. I also looked at a set of N1's but 3k for second hand turbo's just doesnt do it for me.
Thanks
Ian
https://www.sau.com.au/forums/topic/159610-turbos/
ian, you'll be after a set of gt-ss. however i doubt ull want to pay for that little HKS badge, so go and have a talk to dan, he's supplying my turbo's for me.
Another thing is to go and look at the dyno thread in forced induction (its a sticky) as there's a fair few setups and figures in there.
Youll be look at ~3k for the turbo's, then u'll prolly want to change dumps while they are off, and then u need gaskets.
On a side note, give me a figure ud be willing to pay for my N1's and i'll think about it. Also i'm selling those hks dumps, and the trust front pipe.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2963491
Im sending you a PM now shane.
Slide turbos would be good but I think the wait on them is about 2 months at this stage? Also there only rated to 300 kw so I would be close to maxing them out, unless that was 300 kw per turbo.
Shane, more info on the GT SS man?
The HKS GT-SS is the inbetween standards and the HKS 2530. From what i've seen its pretty comparable to N1's. A set of HKS GT-SS will cost you $3032.32 + tax if u get hit from nengun.
I know spilmer (thats his name on here) is running a pair on his gtr.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2963556
I've also been looking around too Ian, decisions decisions....
a mate put some of those garret 2860R's on his 32 GTR and he's very happy, they are very responsive..
I wanted something a little bigger for my GTR but with stock internals i cant. I'm thinking about getting the Garrets too. at less than $2500 a pair brand new you can't go past em..
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2964584
Apparently a well set up to4z can come close to matching the GTSS's down low....I video evidence somewhere!
I attached some turbo rating info but I think it is a little old
Along side N1s and GTSS's I would look at Apexi AX53B70 P21s and Trust T517Zs
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2964670
is that for one or both?
Both
Yeah, price is more or less the same as the 2560's ive been looking at, and this appears to be a kit with all the gaskets etc.
2860R's would probobly be too big for me and response would suffer, but where did you find them at less then 2.5k a pair?
big single!
well how driveable do u want it.? u can have a small single with internal wastegate like some of the BeeR* cars.
but i also second 2530 or GT SS
yeah ive been thinking of going to a medium sized single rated to 450 HP or the like, however airflow may suffer as opposed to the twin setup? Bearing in mind im not chasing quater mile times, its being built to turn and be a daily so midrange is important.
thanks for the pic man, helpful. Not all the turbos im looking at are listed on there but never the less I will look into the turbos your recomending.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965256
BeeR uses a 3037S on their drift RB26 should make the power you want and have strong midrange..afterall that is what they chase in D1!
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965278
ian, keep in mind if u purchase a set of turbo's from nengun, ur likely to get hit with import tax, and that will soon blow the price of the turbo's way up.
going a single would be too much hassle and money. you need new manifold, dump pipe, front pipe, intercooler piping, afm piping, water & oil lines. and then it'd be majorly defectable, caus it'd be the first thing the coppers see when they lift ur bonnet.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2965995
well i dnt remember what they are using lol.. i just remember it was an internal gate single.. that wasnt at all that big.. and was deemed quite driveable.
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2966041
the 2560R's seem the go at this stage, bang for buck they seem to be the best bet.
Hey shane how come ur never on msn anymore?
get them from dan, he'll beat anyone's prices :D
not on msn during the day as im at the toowong office now (until may), and i'm surrounded by stiffs :)
https://www.sau.com.au/forums/topic/159610-turbos/#findComment-2966120
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
